Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos maximum volume
we have an Sharp Aquos TV and want to know if there is an option to change the maximum audio volume limit.
We want to put it on 18 or 19.
Is this possible and if so, can this be done in between certain hours ?
Regards,
Marc ( marc@musicasaservice.com )
    Problem Solver:
  • 14 Answers
There is only the vol level ctrl in the menu
Posted on Jul 25, 2008
The volume is very low, even when I put it up to 60 (its maximum)
if you can open the TV try to connect external speaker to be sure that its the speakers and not the amplifier on the main Circuit
Aug 18, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC46lE700UN How do I adjust the audio. Manual says that the Output Select to Fixed, but it still does not allow me to adjust the audio
If the RCA audio out put is set to 'FIXED' it means the signal at the RCA jacks will not be controlled by the Volume control of the TV, but the TV speakers will still be controlled by the TV volume control, if you want to make the RCA AUDIO out to be adjustable by the TV volume control, you will have to set it to 'VARIABLE'.
Nov 03, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sep 05, 2009 | Sharp LC-26D4U 26 in. LCD Television
How do i over-ride or reset the maximum volume limit on the nano 4g
ok maximum volume on the ipod will only work if you change it yourself. if you havent tried this yet, turn on your ipod then select settings then select volume limit and set it to whatever you want. if this doesnt work you can plug in your ipod and open up itunes and change it from there. the way you do this is right click on the song and click get info in the tabs select options and then you can set the volume limit there as well u can aplify the volume or change lower it
Jul 08, 2009 | Apple iPod nano 4th Generation
My audio and video options are locked.
On your remote, click on "AV Mode." Then change the setting from "dynamic fixed" to any of the other options (you'll probably want dynamic, which is the next option). Then click on "menu." Then you should be able to adjust the video and the audio.
Apr 03, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
338 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
