Question about Canon PIXMA MP780 All-In-One InkJet Printer
I just installed hardware helper and I cannot fax. I just get a busy/no signal. It worked when I was on xp but am now on vista
  • 3 Answers
Http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp780#DriversAndSoftware
Looks as thought there are some software updates available...
Posted on Nov 09, 2010
Windows is showing a remove hardware icon. when I click on it, it wants to remove the cd/dvd..name is hl-dt-st rw/dvd gcc t10n. I've tried disabling the driver and restoring it, disabling device and...
Operating System Windows Vista™ Ultimate, Windows Vista™ Business,
Windows Vista™ Home Basic,
Windows® XP Professional SP2, Microsoft® Windows® XP Home SP2, FreeDOS
Try formatting your windows into windows vista or windows 7. It might solve you problem.
Nov 25, 2010 | Dell Latitude D630 PC Notebook
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
REQUIRE INSTALLATION DRIVER FOR LEXMARK F4270 FOR WINDOWS VISTA BUSINESS EDITION
Go to the following website and enter your printer model (F4270) in the "Search by Model" box. It will then ask you to select your O/S. Vista Business is the same as Vista with respect to printer drivers. Vista 64 bit is one of the options, select it if you have Vista 64 bit. Otherwise try the XP driver
Aug 19, 2009 | Lexmark Office Equipment & Supplies
USB connection with Windows Vista
Install Win XP pro or Win 7 on your computer.
Vista sucks!
Aug 14, 2009 | Sony Handycam DCR-PC350 Mini DV Digital...
I am using quickbooks premiere edition 2008 and when I try to do anything with adobe reader it fails. I really need to get reader working
Try uninstalling the Quickbooks PDF converter.
Open the printers folder:
  1. In Windows XP: Double-click Printers and Faxes.
  2. In Windows Vista: Under Hardware and Sound, click Printer.
  3. Right-click the icon for the QuickBooks PDF Converter and choose Delete.
    1. Open the printers folder:
    2. In Windows XP: Double-click Printers and Faxes.
    • In Windows Vista: Under Hardware and Sound, click Printer.
    1. Right-click the icon for the QuickBooks PDF Converter and choose Delete.
    Jan 29, 2009 | Intuit QuickBooks Pro 2008: Windows
    Upgrading the OS Windows XP not possible
    Upgrading from OS Windows XP:
    you can upgrade from Windows XP to Windows Vista(ultimate, premium, home, business.......),
    you have to buy a Windows Vista CD and install a fresh copy or format.
    Some Minimum Requirements:
    i) Min 2GB RAM or atleast 1GB RAM(if you have>1GB RAM installation of Windows Vista will not continue)
    II) External Graphic Card. for some versions of Windows Vista(to run Aero Interface, special feature only   in some versions of Windows Vista)
    NOTE:
    "Windows Vista Upgrade Advisor" is a software from Microsoft which you can download from internet, this  can help you determine which features and edition of Windows Vista will run on your computer.
     i.e., when u load this software on windows xp it will suggest which upgrade version of windows vista          will suit your system(based on you system configuration. or hardware components.) and then            you can install the upgraded version of windows xp(mostly windows vista home,.........)
    Thanking You
    M. Sridhar
    Dec 26, 2008 | Computers & Internet
    Not possible xp installation
    How to Downgrade Vista to XP Downgrading from Windows Vista to Windows XP is almost like installing Windows XP for the first time. You should take all the normal precautions like backing up all your important files and record important passwords in a different place, preferably on a CD. When you downgrade from Windows Vista to XP, note that Windows Vista will be completely removed from your system.
    (Note: There is a way to have both Vista and XP in a dual boot configuration, but that's an option for more advanced users. See Dual Booting Vista and XP for more info on that.)
    Before you begin the XP installation, make sure that the necessary XP hardware drivers are available, or included on the XP disk provided by your PC vendor. If in doubt, check the vendor's website or poke around with your favorite search engine to see if others have attempted the XP install on the same hardware. You may be able to install XP without all the needed drivers, but some hardware may not work afterwards.
    Also, make sure that you have a genuine Windows XP CD before you begin the downgrade. Be sure to read the section earlier in this article to see if you qualify for a low/no cost XP recovery disk from your PC vendor. If not, perhaps you have an XP disc that came with another computer. If you've upgraded an existing computer from XP to Vista, the best choice would be the XP install/recovery disc that came with that computer. One some PC's the vendor doesn't ship a CD, but the recovery CD can be created from disk images on the hard drive. If all else fails, you can always buy a copy of Windows XP on Ebay. Just be sure it's a legal, licensed copy.
    Follow these steps to install Windows XP on your Vista machine:
    • Insert your Windows XP install/recovery CD and restart your computer.
    • Install Windows XP normally, providing either the product key that came with the disk, or the one you got from Microsoft customer support. If the installer warns you that another copy of Windows is already installed, don't worry. Remember, this install will wipe out your existing Vista installation.
    • Activate your copy of Windows XP when it prompts you to do so. If you run into the "already activated" problem, you can use the option to activate by phone.
    • If you own Vista Business or Vista Ultimate, explain to the rep that you want to use your Downgrade Rights to install XP Pro.
    • If you own Vista Home Basic/Premium, or you are installing XP Home Edition, don't mention ANYTHING about Vista. Just give the rep your XP product key (not the Vista key), explain that you are installing XP on a new hard drive, and tell them you need to activate.
    Mar 30, 2008 | Computers & Internet
    Canon PIXMA MP780 All-In-One InkJet Printer Logo
    49 people viewed this question
    old marine
    old marine
