Make a line diagram for three point wiring - Office Equipment & Supplies
  • 6,694 Answers
HI
LINE DIAGRAM FOR THREE POINT WIRING
OK
Posted on Dec 27, 2010
Wiring diagram for oven element
Don't question the diagram. If that is the way it was set up to work, then just go with the flow and do not improvise.
Mar 12, 2015 | Dryers
How do I get a three phase wiring diagram for a Ipso WE165 washer
http://www.frankshospitalworkshop.com/equipment/documents/various_equipment/user_manuals/washing_machine_dryer/Ipso_WE73-95_-_User_manual.pdf
Feb 08, 2015 | Heating & Cooling
I need wiring diagram for micro door switches
That switch have three points the one in the middle is common point where you will put yo live wire n the other two is normal openand normal close points so yo must first check which one is close n which one is open using ameter on buzer,,,,, its not difficult but you can ask the technician if you fail
Sep 14, 2014 | Microwave Ovens
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
1983 Honda CB 450 SC Nighthawk wiring diagram
Hi, Tazz7495 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1983 Honda CB 450 SC Nighthawk wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
https://app.box.com/v/motorcyclemanuals/file/1091318073 service
https://www.partsfish.com/page/oem-parts-for-honda
https://app.box.com/v/motorcyclemanuals/file/1096145943 owners
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 01, 2017 | Honda CB 250 Nighthawk Motorcycles
2011 FLSTC accessory wiring diagram
Hi Kevin, this is an easy fix, right behind the battery is a black plastic box, the cover slides up and off accessing your fuses. Just splice the positive wire from the power point into an outbound wire from the ignition or light fuse. For a free wiring diagram, please visit the website below. Good luck and have nice day. xlch@mail.com Harley Davidson Wiring Diagrams and Schematics
Jun 02, 2012 | 2008 Harley Davidson FLSTC Heritage...
The pump motor is a two speed 1.5 h.p.. It was factory set for 240 and I had only 110. Technician said we could eliminate one wire and this would accomplish the switch. The motor continually shuts on and...
Your three wire system was 115V? I assume then it was Line, neutral, and ground and you would hook the Line and neutral to the motor line posts and the ground to the ground post.
You also need to be sure to reset the motor from the 230 volt to the 115 volt setting to match the line voltage you are supplying.
Jul 13, 2009 | Hayward 1.5 Hp Northstar High Performance...
AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
Jun 20, 2009 | Carrier 38CKC036 Air Conditioner
Emachine T3958
Hopefully eMachines are consistent with their wiring/layout design, that being the case this diagram for T2898 (by benz18724) should point you in the right direction...
Alternatively compare the abbreviated pin symbols on the header to the motherboard and match them up.
Jan 31, 2009 | Computers & Internet
713 people viewed this question
k24674
Marvin
Marvin
