Question about Intertherm Heating & Cooling
Intertherm oil furnace in mobile home installed 3.5 years ago. Worked great until the Igniter transformer shorted out 1.5 years ago. When technican changed the transformer he also changed the burner noozle. I had so much soot buildup that the chimney was clogged in 4 months. The CSA panel lists a delavan 0.50 GPH 80 A noozle and the tech replaced it with a Hago #559, 90 degree noozle. Would the different noozle replacement be causing the soot problem? I've had a different tech clean out the furnace and chimney but he replaced the noozle with another 559 and the soot continued. I've since shutdown the furnace until I get an answer and the problem solved, but winter will soon be here.
  • 455 Answers
Hello,The 90* nozzle is usally installed in miller brand units because of the "short" chamber.The 90* should not cause soot.Soot = not enough primary AIR into the burner mix.If the unit mfg. wants .50/80*a it should be used.#559 might translate into a .65gph input thus overfiring the unit.If a .50gph is installed the AIR mix problem will take care of itself (less fuel).Soot is unacceptable in your (young)3.5yrs unit and should NEVER have soot at all.The problem started when the nozzle was replaced try (insist) on mfg spec. nozzle.
Posted on Nov 08, 2010
Testimonial: "Good advice. My tech will be here tomorrow morning and I have already purchased the proper 50/80 A noozle as required by unit manufacturer. "
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
I have an electric furnacein my mobile home and it will every once in awhile hum like it is trying to turn on but won't unless I tap the blower cover.
The motor is a 'sleeved bearing' motor, not a sophisticated 'ball bearing' type motor. The bronze sleeves probably need lubrication. Some motors have no oil ports, and are referred to as 'permanently lubricated' motors. If you have oil ports, they will be approximately 1/16" in diameter near the top with little yellow plastic or gray pewter plugs in them. Remove the one plug you should be able to see and gently drop 30 drops of light weight oil into it.
The oil will slowly saturate the felt 'wick' that surrounds the sleeve bearing. The second oil port will probably be inaccessible with the blower installed inside the furnace and unless you are pretty handy, should be left for a pro. Unfortunately the oil port that is inaccessible is the bearing that carries virtually all the weight of the squirrel cage blower and is probably the culprit.
Another possibility is that the capacitor could be bad. With a bad capacitor, it probably wouldn't start on its own at ALL. Also the motor would overheat and would cycle on its internal winding thermostat.
Dec 23, 2014 | Intertherm Heating & Cooling
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
I have a intertherm electric furnace model #FEH=015HA=03 w/ an A coil for my AC. Date code 870902 . It burns out the transformer. It did it about a month ago and it was replaced by a certified electrician....
There is a short in the low voltage wiring somewhere...this type of thing can be very hard to track down and is probably a wire rubbed through somewhere...
Have the electrician install a 5 amp. automotive type fuse in the low voltage wiring right after the transformer to keep from burning up anymore transformers...I would do this even if you think you find the problem...
heatman101
Mar 23, 2011 | Heating & Cooling
I have a Goodman GMP125-5 furnace. A year ago, my circuit board was replaced by a repairman. He also replaced the heat exchanger, because he said it was cracked. It worked great until about a month ago....
it would sound like the pressure switch is not working you can take off ther tubes and by hand put a small drill bit in the and clean the switch , some times this works , on some you can jump out the switch and try and fool it in too working
Jan 08, 2011 | Goodman Heating & Cooling
Smoke coming from furnace
You may have something (paper,dust, etc.) on the electric coils. There may also be a short in the element.
Mar 24, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
237 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
