Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
No longer making ice. On/Off button is blinking. What's wrong?
  • Kenmore Master
  • 1,344 Answers
If you are talking about the light blinking inside the freezer located on the freezer wall, that means that the sensor has gone bad and needs to be replaced. The sensor consist of two parts, the one on one side where you see the light and on the other side of the freezer where the beam actually goes to. This is a real easy fix and the parts can be ordered from apdepot.com
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Nov 08, 2010
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
We have a new 3 month old frigdaire gallery and the Ice makes doesn't constantly make ice and we are always running out. There are only two of us using the ice. What is wrong
The energy efficiency cuts down on the functionality. Newer refrigerators will only make 100cubes of ice in a 24 hour period try lower your freezer temp to -2 to help it run longer.
Feb 15, 2015 | Refrigerators
How do I clear a yellow light on my Scotsman ice maker?
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Dec 02, 2014 | Kitchen Appliances - Others
I have a Manitowoc J series and it will run three cycles and then shut off. I will start again and the same thing happens. everything else seems to be fine.
Chances are the unit is shutting down on an error code. It will shut down after three batches if either A: the unit takes too long to make ice, or B: a harvest cycle lasts too long. You can time a batch of ice with a timer or stopwatch... if you listen you should be able to tell when the "ice making" stops and the "harvesting" begins. Ice making should take about 13-15 minutes and harvesting 1.5 to 2.5 minutes. If I remember correctly the error codes are triggered if the ice making takes 60 minutes or longer and/or the harvest takes 3 minutes or longer. You can tell which error code is tripping by accessing the electronic control board. There is an LED indicator that will blink when you turn the unit on if there is an error present in the memory.
Oct 25, 2014 | Kitchen Appliances - Others
The ice maker has stopped making ice. There does
check the module head, the power wheel often breaks loose and the drive motor no longer is engaged, replace the module head!!
Nov 15, 2009 | Whirlpool ED5SHAXM Side by Side...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Maytag Conquest side by side. We have water in the door but no ice. Ice maker no longer makes ice. It dumped it's last load but has not refilled with water. Water gets to the door but for whatever...
if you hold the paddel on the left side in and dont block the small hole the beam will be sent to the reciever on the right side
the light will not blink but stay on
make sure that the switch on the right side is in the on position
hold in the paddel light should be on and not blinking
if it is blinking replace the emitter and reciever part no 4389102
May 18, 2008 | Maytag Refrigerators
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
rlrguitar
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
