Question about John Deere 2010 Tractor Basic Carburetor Repair Kit
What is the torque settings for a cylinder head of a john deere 2140 turbo and the torque settings for shell bearings of a 2140 turbo
nova2nv
  • 197 Answers
SOURCE: torque spec on a 425 john deere head
Initial torque-115 inch pounds,final torque-186 inch pounds.Intake manifold is 53 inch pounds on all 8 screws.Valves set at 0.010 on all 4.If you go with the new style valve cover gasket {the flat one} be sure to leave the old o-ring in valve cover to keep the new gasket from splitting.
Posted on Feb 09, 2010
  • 246 Answers
SOURCE: john deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
  • 78 Answers
SOURCE: i have a john deere 2140 and the p t o is comin on
Lower the rpms
Posted on Oct 22, 2009
  • 168 Answers
SOURCE: blue smoke hard to start no power john deere
Sounds like you have a piston ring ring problem or valve guides worn. Both will cause blue smoke and hard to start. If you don't know how to do a leak down test then you'll have to give it to someone who does. The leak down test will determine if it's the rings or the valves. Also, check to make sure you don't have too much oil in crankcase
Good luck.
skidooer
Posted on Dec 04, 2009
  • 468 Answers
SOURCE: i need to rebuild a hydraulic cylinder on a john
You'll have to use a spanner type of wrench and unscrew the end of the cylinder. Once it screws out, the ram will come out, and you will have access to all the seals to replace them.
Posted on Mar 16, 2010
Testimonial: "a spanner wrench is needed but it's not threaded. a snap ring must be removed through a small hole in the side then it slides apart"
What torque do I use when replacing the cylinder head on a John Deere 110, Briggs and Stratten 19.5 hp
Stuart,
Do an internet search for torque specs 2011 John Deere D110. You should be able to find the service manual for this product easily.
Sep 29, 2014 | John Deere D110 42 in. 19.5 HP...
Where is the lever to engage pto on john deere 2140, year 1982
This is the link to all the John Deer manuals for the 2140 tractor (and accessories). Unfortunately, when I posted this, the John Deere page was unavailable. If I still can't get it later, I will try somewhere else. Regards, Brian
Jun 19, 2013 | Garden
Need to know the torque settings for the big end shell bearing caps
if you have a rebuild kit. the specs are listed in the instructions.. if not call the parts store with engine info and they can tell you...
Feb 15, 2013 | Toyota Celica Cars & Trucks
Am rebuilding the engine on my Porsche 944s 16v and cannot find details of the Cylinder Head Torque settings.
The torque angle tightening method is now valid for all engines of types 924S, 944, 944S and 944 Turbo including all earlier engines from start of 944 production. When making repairs, the following parts must be used:
Cylinder Head Gaskets
Part Number 944 104 374 14 - 924S, 944, 944S Part Number 951 104 374 01 - 944 Turbo only
Cylinder Head Nuts (12 mm high)
Part Number 999 076 028 02 - all types
Washers
Part Number 944 104 229 00 - all types
Tightening Specifications to Torque Angle Method
Tightening is done in 3 steps:
Step 1: 20 N-m (15 ft. lbs.) Step 2: 90 degrees (114 turn) Step 3: 90 degrees(1/4 turn) Important:
Sequencing must be kept for each step. Threads and bearing surfaces of nuts must be lightly lubricated with oil prior to installation. Washers must not turn while tightening. Create a reference mark if necessary.
Note:
The 12 mm high cylinder head nuts might protrude above the studs slightly on engines produced prior to Feb. 1986. In addition, new head nuts must be used at each repair.
May 23, 2011 | Porsche 944 Cars & Trucks
Saab 95 Aero 2.3 turbo. I need torque settings for big end bearings and cylinder head bolts.
CYLINDER HEAD BOATS TORQUE FIRST PASS 29.5 FT LBS SECOND PASS 44 FT LBS.THEN TIGHTEN ADDITIONAL 90 DEGREES FOR MAIN BEARINGS 15 FT LBS TIGHTEN EACH BOAT ADDITIONAL 70 DEGREES ROD BEARINGS 15 FT LB TIGHTEN ADDITIONAL 70 DEGREES. CRANKSHAFT DAMPER BOLTS 130 FT LBS.
Jan 26, 2011 | 1999 Saab 9-5
How to torque engine heads,rod bearings and main bearing by foot pound?
cylinder head bolt torque for a DOHC Turbo 3.0L V6
92 ft lbs.
cylinder head bolt torque for a Non-Turbo
76-83 ft lbs.
main bearing caps
mark on head of bolt "9" 59 ft lbs.
mark on head of bolt "10" 70 ft lbs.
connecting rod nut 38 ft lbs.
Sep 07, 2010 | 1992 Mitsubishi 3000GT
Torque spec on a 425 john deere head
Feb 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Torque settings clio 1.5 dci big end shells
whats the torque setting for big end bearing bolt and cylinder head bolt for toyota corolla 12 valve 2E,1990.
Jan 12, 2010 | 2000 Renault 181
John Deere 2010 Tractor Basic Carburetor Repair Kit Logo
409 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
