Question about Kodak Office Equipment & Supplies
Carousel on my projector does not advance not sure if I have the carousel on right or whats going on.
    President:
  • Kodak Master
  • 412 Answers
Please re-post this problem with the specific model name/number of the KODAK projector. The model (and age) of your projector will determine what is wrong.
Posted on Nov 09, 2010
My Kodak 650H slide projector carousel won't advance?
Chances are what you need is a new cycle solenoid LINK. They can be purchased from: www.micro-tools.com They should have instructions to help you install the new part, as well. Good Luck!!
Jim
Apr 10, 2014 | Kodak Carousel 600 Slide Projector
Buttons will not advance carousel
Hardrocko is correct with his analysis. I have attached an image from one of my Service Manuals that may assist you when performing the repair. Good Luck !! Jim
Dec 02, 2013 | Kodak Carousel 4400 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
We have a Kodak Carousel 650A projector. (140 slide carousel) Cannot advance the slides using the remote or the select bar. Putting in the individual slides with the carousel off the select bar will eject...
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
Jun 20, 2010 | Office Equipment & Supplies
We actually have a kodak 600 carousel projector that will not advance the slides. there is a white "arm" that doesn't move right. Is there a small screw that should be attached?
Given the age of your Carousel Slide Projector, my guess is there is a broken "link" in the slide change mechanism. This "link" is plastic, and connects the cycle solenoid to the slide change mechanism. Over time, the "link" gets brittle & breaks, giving the failure condition you describe. You should consult an Authorized Repair Dealer to see if they can still get parts for your projector, which was built between 1964 and 1972. Best of luck !!
Jun 27, 2010 | Kodak Carousel 4400 Slide Projector
Removed carousel midway by lifting release as a slide fell down,
With the tray removed, cycle the projector in Reverse button 5-6 times. If it is just a mechanism jam from removing the tray mid-cycle, this will cure it. To set the tray back to Zero, FIRST make sure the locking ring is in place and tight on the top of the tray. Then turn the tray upside down & release the latch and rotate the bottom plate back to it's home (Zero) location.
Apr 26, 2010 | Kodak Carousel 4600 Slide Projector
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
My slide projector is advancing the carousel non-stop and I can't control it. What's the problem?
either the switch terminals are making a constant contact, or the advance solenoid is shorted on. you'll have to take the control panel apart to see if the switch pieces are touching. if not, you'll have to either find the short or take it in for repair.
Oct 14, 2009 | Kodak Carousel 4600 Slide Projector
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
79 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
