Question about MTX Thunder 942 Car Audio Amplifier
Why do the wires on the speak termal is sparking
  • 6,993 Answers
the are sparking because there is a partial contact. The wires are not connect firmly to the speaker termal
Posted on Nov 08, 2010
Spark knok
If you mean "spark knock", what about it? In newer engine there are knock sensors that speak to the ECU and control ignition timing to eliminate spark knock.
Jul 27, 2015 | Cars & Trucks
How do i access the alternator on a simplcity 9020 powermax tractor/
Two wires(black) from alt to rect.
Red wire from alt. to reg.
Ammeter wire to battery termal on back of ignition switch.
Feb 28, 2012 | Garden
Missing when accelerating
Hi, from experience its more likely it is the spark plugs and/or wires.
Maybe even the distributor cracked. At night pop the hood start the car look around the wires and cap look for blue / white arking.
Generally speaking, bad spark plug cause missing...
Jul 24, 2011 | 1996 Toyota Land Cruiser
Hey.. the zebra printer z4m is sayin "ribbon out" but it doesnt take ribbon. So how do i fix it?
go to the setings, and check Direct Termal or Termal transfer, Have to be Termal transfere, then run manual calibration, if still going, try to go tu Ribon sensor and change the number, possible is to higth 250...?) change to low number, and try to calibrate again.
Nov 23, 2010 | Zebra Z4M Printer
Ribbon in Printer Idle error
xgech if using ribbon, change the seting to Direct termal, if not, change to Termal transfer. save,(press 2x the enter button) restart the printer
Nov 05, 2010 | Zebra S4M Thermal Label Printer
Installing ink catridges in ux-41 model
It is a termal paper fax.doesn`t need any ink or etc.use only termall paper.
May 29, 2010 | Sharp UX 510 Plain Paper Thermal transfer...
My 1998 Ford expedition does'nt have spark plugs or wires. It says it's a 5.4 v-8
you vehicle has coil on plug ignition system. each spark plug has a coil on it. there are no conventional plug wires, so to speak, that carry high voltage to the plug. there are however, small primary wires the provide t12 volts to the coil which is on top of the plug and is screwed to the manifold.
http://www.aa1car.com/library/copign.htm
May 21, 2010 | 1998 Ford Expedition
Quit heating
How old is this dryer? Use a volt-ohm-meter to check your termal cut-off and thermostat. IF these check out ok, check for a hidden break in the element. Also, check the wiring leading to the element, cut-off and thermostat. Check for breaks in the wiring that might be causing a short.
Dec 14, 2009 | Amana Dryers
Heater works, not blower.
Chech the blower motor to see if its working. Unplug the wire harnes and run a jumper wire to the blower motor. you will need two wires, one hot, one negitave. Put the + on on termal and the - on the other termal. make sure the wires do not touch each other and see if the fan motor will turn. If not, the motor is bad and has to be replaced.
Jan 01, 2009 | 1998 Volkswagen Passat
MTX Thunder 942 Car Audio Amplifier Logo
49 people viewed this question
Top MTX Car Audio & Video Experts
Mike Duncan
Mike Duncan
Philip Armitage
Marvin
Marvin
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
