Question about Texas Instruments TI-5032 SVC Calculator
I am looking for a replace ink cartridge for the T1503511 the part number is IR-40T where do I get a replacement?
  • 23 Answers
Available IR40T Ink Roller
Posted on Nov 15, 2010
Ir2270 not sensing toner
Simple That problem is in the Developing Unit. If you check the DV you will find on one side it has gears remove the screws to expose the gears. Then look for the small round copper metal in front of a gear thats your culprit. Replacing it is the best way. Or clean it if no replacing part is available.
Apr 18, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Where can I buy a IR-40T ink roller for my HR-100TE Casion Calculator?
I get all of my stuff from Amazon. com. Sometimes Office Depot will have it, but you need to be SPECIFIC about which model you have
Sep 08, 2011 | Casio HR-100TEPlus Calculator
What size ribbon does it take...It says IR 40T but can not find it in.. help
IR40T is the Korectype brand of ink roller. You should be able to get this at any office supply store. I don't know where you live but if you are close to Staples they will carry it ot another compatible brand. It is not actually a ribbon but a roller on a piece of plastic. I hope this helps you.
Mar 17, 2011 | Casio FR-2650A Calculator
I need a TI-5045 ink roller or IR-40T ink roller. Where do I get it?
I use the IR40T it is a generic brand that works just as well & is easier to find in stores. Any office supply store carries these ink rollers eg: Staples (if there is one close to you)
Jan 31, 2011 | Texas Instruments TI-5045 SVC Calculator
Where in South Africa can I buy the ink for the TIME CLOCK TC100 ROYAL. It is urgent
Wantitall have them
http://www.wantitall.co.za/Royal-IR-40T-Ink-Pack-for-Model-TC-100-Time-Clock-2-Pack__B0001D7NZG
Jul 26, 2010 | The Times ROYAL TC100 TimeMaster Time...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
After changing the ink roller, the machine is printing nonsensical characters.
You have a IR 40T replacement cartridge instead of a 40T
These are sold under the NR42-2 number as replacements for the Sharp 1801P but they do not fit. IF you look closely at the Sharp Models it lists on the package, it will say Sharp EL-1801V. I have not found a working replacement yet.
Dec 02, 2009 | Sharp EL-1801P Calculator
I just purchased an HP Photosmart C7200 All-in-one printer, loaded the ink cartridges and the screen says the magenta cartridge appears to be missing or damaged. I put in a new cartridge- same message...
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP Office Equipment & Supplies
Replacing ribbon
if you have the same one I have, the Basix BX-PC 102 12 digit printing calculator it doesn't use a ribbon. (maybe that's why there's so inexpensive) It uses an ink roll - IR 40T. I'm searching for one locally now and can't find it. It seems you have to order them online.
Jul 22, 2008 | Basix BX-PC102 Calculator
Need help w/ink
Hi...This calculator takes a IR-40T ink roll.
Turn off the power.
Open the top cover,
There is a flat tab on the ink roller, lift up, remove.
Hold the new roller by the tab, line it up in the slot and snap in.
Turn on the power and test.
If it doesn't work you might not have it snapped in properly or all the way.
Good Luck........
Squipps
Jan 08, 2008 | Casio HR-100TEPlus Calculator
Texas Instruments TI-5032 SVC Calculator Logo
203 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
