Question about Maytag Neptune MAH5500B Front Load Washer
Clothes are still soak after spin cycle is finished, i have to ring the clothes dry before placed in the dryer
  • 144 Answers
Check the manual for info on filter cleaning, you may have a blocked filter .
Pete
Posted on Nov 08, 2010
I have a aeg washer/dryer- it washes fine but then I have problems drying Any idea how I can solve this? problem
Please start with your clothes after the washer finishes it's washing cycle.
Take them out and see how dry they are.
They should be nearly dry.
If not, perhaps the reason you are having problems is they are too wet to begin with for the dryer to properly do it's job..
This is not a rare problem.
One possible reason for the clothes not to be dry when the washer finishes is a loose or worn out belt under the washer.
Another problem some washers have, particularly washer/dryer combos, is that they are sometimes not very effective.
In that case, either smaller loads or rerunning the spin cycle at the end of the washing cycle might help you.
God bless your efforts.
Nov 30, 2015 | AEG Washing Machines
End of cycle keeps beeping even after clothes are finished and removed
this could range from a simple processor hanging problem to a defective pcb
please start from a hard reset by leaving the unit plugged off from wall power for one night
Jul 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
I have an LG gas dryer only 7yrs old. Some loads are coming out still soaked after the cycle has finished. I've looked through the back of the unit and the flame is igniting. However, I have noticed that...
i am not a dryer expert,so i can only make these suggestions.
1.make sure the lint filter is very clean.
2.make sure the dryer is sitting level on the floor.(if it isn't sitting straight on the floor,the clothes may not be touching the sensors,causing the heat to turn on & off while drying.
3 do not overload the dryer with wet clothes.
4.pick the right heat setting for the amount & type of clothes.
Mar 30, 2015 | LG Dryers
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Will not dry. On the dry cycle the cloths get
check lint trap if plugged clean it maybe vent is plugged.
Dec 21, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Maytag Neptune MAH5500B Front Load Washer Logo
73 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
