Question about HP Photosmart C5280 Printer
Paper feeder not working keeps saying load paper
  • HP Master
  • 7,733 Answers
  • 105 Answers
SOURCE: document feeder appears broken in my HP officejet 7310
I'm sure this will solve your issue.
all the best.
Posted on Oct 05, 2008
futureloginn
  • 734 Answers
SOURCE: Paper Jam feeder
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
  • 10 Answers
SOURCE: my lexmark t520 says "load mp feeder letter"
Easy one. Open your tray back up and make sure that the paper settings are reflecting the type of paper that is in the tray. The times that I have seen the issue that you just described, the paper setting were off... thus causing this issue.
If that does not work. Powercycle printer. When it comes ready go to the Paper Menu, then to Default Paper source. Make sure that setting reflects the tray that you would like the printer to print from.
Hope that helps.
Posted on Mar 19, 2009
SOURCE: printer asking me to Load MP Feeder with A4 - the
factory reset should fix it unless the paper size ciruit board and levers have been physically damaged (back left on the printer in paper tray slot)
Posted on Jun 10, 2010
SOURCE: automatic document feeder pulls paper through only part way
You need to replace the document feeder motor the gears on the motor shaft are split and slipping. New motor is 12.72 at http://www.compassmicro.com/parts2.cfm
Posted on Jul 13, 2010
My printer says load paper then press start, I have paper in there and it wont print.
Dont know what you have already tried but first off verify that you are loading paper to the correct tray. Now this tray is going to have a switch located toward the feeder that tells the printer paper is loaded make sure the paper is back far enough but not to the point where you are forcing the paper into the feeder. If all this still doesnt work try reseting the printer and printing a test page. Hope this helps.
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
I keep getting a Load MP Feeder Letter message. I can't clear what to do?
MP Feeder refers to Multi Purpose Feeder or Manual Paper Feeder or just plain bypass feeder. There should be a door that folds down to gain access to your MP Feeder tray. Try loading letter size paper on this tray.
Nov 24, 2009 | IBM Infoprint 1332 Laser Printer
Paper feeder not working properly
did you load your papers the right way? Look on your paper tray. There should be a few snaps right on the sides of your paper tray. Make sure you use those snaps to keep your papers confined in your paper tray
Mar 20, 2009 | HP Photosmart 2575 All-In-One InkJet...
Bulk feeder keeps jamming
It might be the tray Feeder not placed properly or the printer needs a service if not done in the last six months. Contact to your nearby Repair shop and Service centre.
Thanks
Scott
Feb 06, 2009 | Kyocera FS-4000DN Laser Printer
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Loading paper from top.
there is a button to press to swap it from the back tray and the bottom tray. it sounds like you might have some thing stuck in the rear feeder causing the paper not to go through. i would try it from the bottom feeder and see if it works,
might be worth turning the machine off and unplug it and then try turning it upside down and shaking the machine, to see if anything come out of it.
If not i would say to take it apart or call a service engineer out.
Hope this helps
Oct 20, 2008 | Canon Pixma MP500 All-In-One InkJet...
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
False paper jam
Ensure that:
The paper is a recommended paper for inkjet printers.
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Printer
Have you tried switching your printer to load from the back feeder using the feed switch button?
Oct 30, 2007 | Canon PIXMA MP510 All-In-One InkJet...
HP Photosmart C5280 Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
