Question about Dremel 395 Variable Speed Multipro Rotary Tool Kit
The blade assembly on my dremel will not come off. Is there a trick to this?The coupling seems to stuck.
  • 7,733 Answers
Try some W-D40 and gentle hits on the coupling to liberate the chuck 3 pin holders.If you got this type of chuck:
The blade assembly on my dremel will not come off. - r00130v1.jpg > Enlarge Image
4486 Dremel Chuck
The Dremel Chuck holds Dremel accessories without using a collet eliminating having to use the wrench and creating quick and e
Posted on Nov 08, 2010
Attatching dremel blade
You can't attach this to a Dremel Stylus. This blade is specifically for the Multi-Max tool. A link is below.
http://www.dremel.com/en-us/Tools/Pages/CategoryProducts.aspx?catid=2094
Oct 21, 2012 | Dremel Multi-Max MM462- 1 3/8 inch BiMetal...
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
The pot metal in front of thequick release tension lever has broken and fell out. can I still use the saw If not where do I go to get another one 1830 120v 18inch scroll saw dremel
I believe the part you are looking for is called a "locking rod" dremel part number 2610922661, this is the black painted pot metal that is about 3" long attached to the upper arm rocker with a parallel pin, and the flip clamp (blade tensioning assembly) or it could be the small piece attached to the tension assembly that the blade attaches to which is silver and called the "blade holder assembly-top" part number 2610922683. I would recommend ordering both directly from Dremel CS 1-800-437-3635. I broke the locking rod on mine. I emailed dremel, and they emailed me back the next morning with a schematic, and parts list. I bought 2 and paid $10.41 total.
Mar 08, 2011 | Dremel 1830 120V 18" Scroll Saw
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
My blender seems to spin without the glass blender "jar" in place. Once the blender is put on top, the blade will not spin.
your blade assembly is corroded. take it off, and using a rag, grab the blades. using another rag, grab the other end (probably rubber) and turn CLOCKWISE - it's threaded reverse, so you have to turn to the right to loosen, not the left like usual. I had to clean out the rod that connects to the blades - it was all nasty and corroded. I cleaned it with my Dremel and regreased with a tube of grease I keep in the garage, cleaned all other parts with some Dawn, dried well, reassembled, and works almost like new. I'm guessing I ran it too long without pulsing the motor and the heat corroded the rod that's connected to the blades. OR you can buy a replacement blade unit for about $10 online on a blender parts site
Oct 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
How does the blade move on the dremel motoshop 571-5? My motor seems to be stuck.
You need to have a blade installed... the unit locks itself when there is no blade
Aug 05, 2009 | Dremel Saws
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Nov 13, 2008 | Dremel 300-N/55 300 Series Tool Kit
Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Oct 22, 2008 | Dremel 16472 Carbide Coated Scroll Saw...
Dremel 395 Variable Speed Multipro Rotary Tool Kit Logo
283 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Sheldon Dedek
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
