Question about Panasonic PV-GS35 Mini DV Digital Camcorder
Panasonic GS35 We have black horizontal lines appear when we play back, It started after the camcorder displayed that the head required cleaning. After we followed this instruction, we have a problem with these black horizontal lines. They are not visible on the lcd in the recording mode, but appear when we play back.
  • taste Jun 26, 2008
    I will try and insert a head cleaning casette,again, and report back.
    Thanks again for your help
  • 95 Answers
I suggest you insert a head cleaning casette to see if this removes the lines.the lines occur when one of the heads is dirty or not operating. if this does not solve the fault then the head might need changing.
Posted on Jun 25, 2008
HORIZONTAL lines appearing on the display screen
If the line appear when ever you are playing back the job you have recorded with the camera,it might be as a result of dirty on the play head of the camera.So you will need a head cleaner tape.But if the problem continues after cleaning the play head of the camera needs to be changed
Aug 23, 2013 | JVC GR-D32 Mini DV Digital Camcorder
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Black lines on playback no playback
hi, if you have stuck the head cleaner in and this has not removed the black lines then the head might either need a thorough clean or may be damaged.
Jul 03, 2008 | Panasonic NV-GS17 Mini DV Digital...
Camera Will Not Play Back Video!!
normally you receive a head cleaning tape with the unit or you should purchase one and let it run untill it stops playing. i suggest you run it 2-3 times if this does not solve the problem then you may need a head chage. the change will have to be done by a qualified technician.
Jun 24, 2008 | Panasonic PV-GS35 Mini DV Digital...
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
No LCD Display when opened at 90 degree
Dear sir, If the Picture in View finder is connect, then problem in LCD ribbon cable. LCD Ribbon cable may damage. Replace LCD ribbon cable. thank you, replie if any problem
Jan 17, 2007 | Panasonic NV-GS35 Mini DV Digital...
Taping over previously recorded tape
I too had same problems its because your tape head is not clean use a head cleaner cassette and play it, your problem will solve
Nov 19, 2006 | Panasonic NV-GS35 Mini DV Digital...
Open Questions:
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
181 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
