Question about Homelite Garden
I have an old homelite bandit bx90/150mph is there a gas filter in the gas tank? Thank You.
4 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: homelite zr series z25mhv/160mph fuel line and
Take a piece of your old hose to your local hardware store and compare the ID of PVC tubing, this should work fine
Posted on Mar 24, 2009
bbreton
  • 437 Answers
SOURCE: BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Posted on Oct 14, 2009
rwvanlue
  • 486 Answers
SOURCE: Homelite bx90 leaf blower: won't run in cold weather
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 16, 2009
On a homelite model 26 bv blower Does the gas tank filter connect to anything
The filter fits on the end of the fuel pickup line inside the gas tank. If you see the filter just rolling around in the tank it probably has hardened or damaged fuel lines. Size them up and get replacement lines online or at your local outdoor equipment retailer.
Oct 06, 2014 | Homelite Garden
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
Gas tank
Homelites are great, especially the old aluminum gas tank kind like the C-55. If it leaks through the gasket you can take it apart and trace out a new paper gasket on a piece of cerial box. Make sure to wash the gas filter bob in gas and blow it out to get the film of fine sawdust off it or it will lock up with vacuume from the engine while cranking. If it cracks you can use 2 part epoxy putty stick which is made just for gas tank repairs.
Jun 04, 2011 | Homelite Garden
Gas/oil ratio for Homelite Bandit UT10901A chainsaw
100-130 ml oil for 5L gas ! its OE info.
Thank you for rating.
Mar 22, 2011 | Garden
How do you attach the fuel line to the filter inside the gas tank
have to pull the line out of the tank enough to put new filter on i use an old wire coat hanger cut and with a hook bend on one end if line is to short have to replace line
Dec 15, 2010 | Homelite Garden
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
Homelite won't start
You may consider installing a new spark plug. 2-cycle engines foul plugs pretty regular. I'm guessing you are using old gasoline??
Aug 17, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
The trimmer I have is a sx-135 bandit. which fuel line pulls fuel from the tank
The longest of the two lines is the one that pulls the fuel from the tank. It should also have a fuel filter attached to the end of it which lays at the bottom of the tank.
The other line goes form the primer bulb on the carb. to just inside the tank ( about 1/2 in to 1 inch).
Jim
Jun 12, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you replace the fuel filter on a homelite st 145? the hose snapped and the filter fell into the fuel tank. Thanks
Take the old piece of fuel line and have the vendor match the size. Buy 1 ft. so that you have a little extra to work with. Cut fuel line at an angle. This will allow for easier insertion into the hole in the gas tank. Feed the line through until you can pull it out of the opening where the gas cap is. Cut the line off square. Attach the fuel filter. Pull the line back through until it rests comfortably on the bottom of the tank. Assemble the trimmer. You will then get a more accurate measurement to the carburetor.
Jim
Jun 10, 2009 | Homelite Garden
Garden Logo
221 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
