Question about Sony STR-DA3000ES Receiver
Volume adjustment malfunction - turning knob clockwise or counter may increase, decrease or not affect volume at all
4 Suggested Answers
jcameo7270
  • 675 Answers
SOURCE: center channel volume decreases in surround mode,
There should be a setup button or menu button...when in setup go to surround settings and change to desired volume
Posted on Dec 27, 2010
  • 1043 Answers
SOURCE: My volume knob is working in the opposite
You can go to the following website and it lists a Harman Kardon shop in your area:
http://businessdirectory.bizjournals.com/orlando/shopping_consumer_services/3302727/beach-tv-repair.html
Posted on Mar 17, 2011
hi .. if you go to manual setup for speakers level and turn down the volum of your front speakers and set center to max then your problem should be solved .
in some amplifiers you have an option called dialogue level set this one to max it sould help .
good luck , have a nice day
Posted on Aug 08, 2013
How to adjust idle linkage
there should be a screw around the air filter somewhere that can be adjusted without taking anything apart. Turn it clockwise to increase the idle counter clockwise to decrease.
Jul 26, 2014 | Ryobi Garden
How to turn the volume up on ipod nano2gb
Run your finger clockwise around the circle that has "Menu", "Fast Forward", "Rewind", and "Pause". Clockwise increases the volume and counter clockwise decreases the volume.
Jun 29, 2014 | Apple iPod nano
How do I adjust the temperature on heat stik aquarium heater
you turn the knob - clockwise to increase, counter clockwis to decrease. Always wait at least an hour for the tank temp to reach the new setting. Only make small 1/4 turn or less) adjustments at a time
Nov 27, 2013 | Deep Blue Professionals Deep Blue Heat...
My Amplifier is in good working condition, except for the volume control has gone weird Using the remote, you can increase volume, but not decrease volume. On the unit, rotating the volume control...
Cleaning the contacts may help. The volume knob should pull off. Once its off use a non-flammable contact cleaning spray to clean the contacts behind the knob.
Electronics and automotive stores should have this.
May 16, 2011 | Onkyo TX-DS494 Receiver
How do I adjust the volume on the KX-T7456?
on the bottom right hand corner of your phone, rotate the dial clockwise to increase volume, or counter clockwise to decrease(must be done DURING a call)
Jan 04, 2011 | Panasonic KX-T7456 Corded Phone
The ice maker on my Amana side-by-side isn't working right. Too much water. I have replaced the valve twice and it works ok for a little while. What else could be wrong?
Take a look at this web link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
About 1/3 of the way down the page there is this statement with picture:
FILL ADJUSTMENT SCREW
1 full turn will affect fill by 40cc. 1/2 turn varies the fill by 20cc.Some Ice Makers May have knobTurning the knob or screw clockwise decreases fill; counter-clockwise increases the fill amount.Turing Adjustment Screw More than 1 full turn could damage module.
If you have 2 times replaced the water valve and you still tend to think the water valve is the problem again it may be time to use an IN-LINE water filter as you just may be getting particulate introduced into the ice maker water valve from the house connection. Particulate in the ice maker water valve seat causes them to bypass water when they are not supposed to.
I tend to think your in the right track and thinking the problem just may not be the water valve.
Use the link to troubleshoot. Just remember though that each time you cycle the ice maker using the jumper as instructed it will fill with water.
What I would to is pull the plastic hose in the back and cycle the icemaker BEFORE you make any adjustments catching the fill water in a measuring cup behind the unit. Note volume...
Make adjustment... Note volume difference. You should not have to make much more than a 20cc adjustment.
Thanks for choosing FixYa.
Kelly
Sep 27, 2010 | Amana Refrigerators
HOW DO YOU ADJUST THE SCAULD LEVEL
Remove the handle and bezel (face plate). Locate adjusting screw and turn right (counter-clockwise) to increase temp. or left (clockwise) to decrease. Check for desired temp before replacing face plate.
Jul 19, 2010 | Delta & Single Handle Shower Faucet
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Universal remote
dont know how to program the remote, but u can adjust the volume manually by using the dial. similar to an ipod if you move your finger clockwise around the dial the volume will increase, and counter clockwise will decrease
Oct 07, 2008 | LG LFD790 System
Open Questions:
Sony STR-DA3000ES Receiver Logo
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
