Question about Samsung DV337 Electric Dryer
Drum want turn, everything else shows ok - Samsung DV337 Electric Dryer
  • Samsung Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Just fitted a new belt to my dryer now it wont turn have checked for any loose wires
Are you sure you have the belt on correctly? When you start it does the motor run or try to run? Does it hum or buzz when trying to start? Take the belt off & start it see if the motor runs if it does check if drum, belt and idler pully are installed correctly.
Check the drum rollers and drum glides be sure the drum turns ok. Be sure everything is installed correctly & turns OK . Are you getting power? Hard to tell what is wrong without much information about what is going on. You might check the front panel & see if it is binding on the drum not letting it turn. Hope there's something here that will help you.
Jun 02, 2014 | Frigidaire Electric Dryer
The dryer heats, motor runs but drum doesnt turn.
Could be one of several things. The drum turns by motor and fan belt around the drum. The most common problem is that the fan belt is broken. Check to see that the drum is free and not bound up by frozen bearings. Also that nothing is jamming the drum. If everything seems to be ok --- you need to check the pulley on the motor shaft and be sure it is tight on the shaft . More than likely -- it is a broken belt. I hope this helped.
Dec 14, 2010 | Amana ALG443RAW Gas Dryer
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Hotpoint vtd 20 drum is not turning,everything
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 11, 2010 | Dryers
Drum Turning Ok but....
If this unit belongs to the landlord, you can have him take a look at it. It may be that he knows how to repair appliances, if not, contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will happy to assist you with this repair.
The best of luck to you and we hope you get everything working great!
Nov 09, 2009 | Washing Machines
Drum has stopped working. everything else seems to be ok
If the drum has stopped working it can be a few things.
  1. Moter
  2. Water level sensor (doesn't know if the water level is right, so it does not turn the moter).
  3. bad belt for the moter.
All good things to check.
Oct 14, 2009 | Washing Machines
No heat. Gas valve is on. Drum turns ok, blower works ok, everything else seems to work including other gas appliances
either the flame sensor eye is dirty and not letting the gas valve stay open, your gas solenoid coils,or the control board are defective
Oct 02, 2009 | Dryers
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Hotpoint WMA 22 drum not turning
Hi, common problem with this make of machine but easy to repair. Take off the lid and make sure it is un plugged from the mains...... You will need a pair of hook nose pliers to remove the carbon brushes from each side of the motor. They should be an inch long if not there is your problem.. Just replace and it will run.
Let me know how you get on..........
Nov 24, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Samsung DV337 Electric Dryer Logo
83 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
