Question about Brother HL-2040 Laser Printer
The toner light stays on even after we have replaced the cartridge with a new one. Recently we replaced the drum and it was working ok for a short while and then the toner light stays on and the printer will not print unless we take the cartridge out and shake it. It then prints a couple of sheets and stops with the light on again.
  • 863 Answers
Here you got bud just copy and paste all this **** below into the http:// window at the top of your web box:
http://docs.google.com/viewer?a=v&q=cache:uNJvw-MWncQJ:www.oasis-imaging.com/images/pdf/cart_inst/Brother%2520TN360.pdf+Brother+TN360+by+OASis&hl=en&gl=us&pid=bl&srcid=ADGEESj4M8XLUS4yMo7hAf3nTuGGvKtaYS5_tHhGdh9WoDGinffOkVJPv8cp642xaSG5PkbrNrcUssyMY1ggc1xYlSZEu-JNeY4iVcXWD9O7MKza5_7CjyQyTPW7nnZeAQWm_d7f-MEE&sig=AHIEtbTarYNPKakKRnVcXg3pW_PBoi_4tA
You gotta reset the plastic piece at the end. Also, get you some black electric tape and tape the 2 circular clear plastic plugs on each end of the cartridge. The sneaky bastards at Brother shoot a laser through these clear plastic plugs and when the toner goes below these plugs that causes your printer to say your out of toner even though your not. Therefore if you tape over these clear plugs, then you can squeeze another 225 pages of pure printing bliss without needing a replacement.
Posted on Nov 11, 2010
I recently changed my copiers toner (the change toner light came on) and now my copies are uneven (alternating in light and dark patterns). I properly shook the toner, I even returned the toner to get a...
The light and dark banding going horizontally accross the page is usually caused by the drum unit. This is the smaller of the 2 cartridges and it sits just to the right of where the toner sits. If you have a spare drum unit, replace it. This should resolve the problem. The Toner cartridge can also caus this but if you have tried 2 DIFFERENT units with the same banding then it must not be the toner.
Good Luck and Thank You for using Fixya.
Jun 15, 2010 | Sharp AL-1642CS Copier
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Low print quality
It depends upon the number of prints you have done since Feb and the toner cartridge capacity. Some toner cartridges have 2500 page capacity others have 5000 pages or more.
If you think you have not exceeded or reached the cartridge capacity, take it out of the printer and give it a shake in a horizontal position to distribute the toner evenly across the drum and place it back in the printer. This also works when the toner is nearly empty.
Sep 09, 2009 | Brother HL 1440 Laser Printer
Can Xerox Phaser 6280 be refilled by Consumers?
The 6280 uses a specially designed toner called Emulsion Aggregation toner. This is a special type of toner made by Xerox. Sice it is so new and patents exist, I doubt that anyone can legally make the toner, even if they posessed the equipment and the expertis. Refilling with non-EA toner is asking for big trouble.
Aug 12, 2009 | Xerox Phaser 8200 Laser Printer
I have a Sharp al 1010 that is always indicating the toner is out, even though I replaced the cartridge with a new one (twice..thought there was an issue with the toner cartridge). Also recently replaced...
if you have replaced the toner unit the main cpu is bad not realLY worth fixing but this is a very good copier you can get them on ebay , this the only copier you can refilll the toner unit for $6 & DRUM FOR $15 get a AL1655 best deal
Mar 03, 2009 | Sharp AL 1215 Black and White Copier
Xerox wc 220 mfd
In FAX mode, try printing a FAX ACTIVITY REPORT from the FAX OPTIONS MENU. IF the print is OK, your scanner light may be defective, and must be replaced by a technician. If the print is black, the DRUM or something in the DRUM CARTRIDGE has no ground or shorted ground. Remove the DRUM CARTRIDGE and CAREFULLY brush or vacuum any loose toner you can see, and reinstall. DO NOT TOUCH THE DRUM ITSELF! IT WILL BE PERMANENTLY DAMAGED BY EVEN A FINGERPRINT! Otherwise, you may have to replace the DRUM CARTRIDGE. It can be purchased as a supply item.
Nov 15, 2008 | Office Equipment & Supplies
Status red and amber Toner light
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Aug 09, 2008 | Brother HL-5240 Laser Printer
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Bad copies and prints after changing the drum and toner cartridge
Did you clean the corona wire when you replaced them? Even with the Drum being brand new, you still need to run the little piece of blue plastic back and forth across the wire that is called the corona wire. If you don't know where that is, and do not have the complete software for your printer - you can find that at the link I have provided below. The short version is that it is just in front of the toner cartridge on the drum housing. If you do have the software, open the user manual and look for the table of contents listing that refers to replacing toner and drum cartridges. This will show you a picture of where the corona wire is.
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID=%7b2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8%7d&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top%2ehtml%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc7420_all&NRCACHEHINT=NoModifyGuest&prod=mfc7420_all&reg=us&c=us&lang=en
Jun 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Blank pages after installing new drum
when replacing the toner did you remove the plastic film sealing the toner? if the drums receives no toner you will get blank pages. please check
hope this helps
good luck
Oct 25, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
140 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
