Question about Panasonic PV-GS35 Mini DV Digital Camcorder
Thick lines on screen
Inch thick dark lines are on the screen of the viewfinder and television. Why is this and how can they be removed? Cheers I have the same problem. It started after the cam corder indictaed on the LCD that the head needs to be cleaned. After we cleanded the head, it started with the black horizontal lines spaced about the same distance as the bid that does not have the lines. No problem while recording, (no lines), but as soon as we play back we get the horizontal lines????
  • taste Jun 23, 2008
    Probably no7 what I wanted to hear. I will take the Recorder to a service centre, and get a quote.
    If it is to much, it will go in the trash can. One thing for sure, this is the last time that I have purchased a PANASONIC. NOT WORTH THE MONEY. I WILL BUY THE CHEAPEST RECORDER NEXT TIME AND TRASH IT WHEN IT FAILS.
    Sergeant:
    Champion:
  • 230 Answers
It may be because of the fault of the screen i think you need to change the display
Posted on Jun 16, 2008
  • 790 Answers
Hello taste!!
Have you moved the "save protection" tap to the "allow recording" position! Try this!! And please dont clean the head anymore with the cleaner!!
Regards
Smilemaker
    President:
  • 2,712 Answers
Try a hard reset first: remove battery, unplug from AC source, remove all recording media and wait 10 minutes.
If that doesnt resolve the issue, it could be an issue with the circuitry. Try replacing the cable btween camcorder and TV and see if that helps..
  • Swilin Sampson
    Swilin Sampson Jun 16, 2008
    Could be that you damaged the head while cleaning it. Try cleaning it again with isopropyl alcohol on a q-tip. Wait for it to dry completely and make sure there is no fibres, etc left behind. Try again and see, If you still have the same issue, the playback/recording head may need to be replaced.
    If you found my solution helpful in any way, kindly take a moment to "Accept" my solution.
    If not, please post back and I will try to assist you further as best I can, Thanks!
  • Panasonic Master
  • 13,433 Answers
I think this requires a professional diagnostic done on the device. I would suggest you contact your dealer or panasonic for repairs, it seems quite serious.
How do i remove the thick black line at the bottom of my tv screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 19, 2014 | Luxor 27 Inch 2 Shelf Mobile TV Cart -...
Black thick line going horizantal on screen can it be fixed?
Usually a bad board but someone has to open set and troubleshoot to decide which board is the problem.
Apr 08, 2012 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
3 inch thick black line almost at centre of screen
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 03, 2010 | Samsung PS50A466 50 in. Plasma HDTV-Ready
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Thick dark vertical lines appear on the video taken during playback.
It is problem of dirty / clogged video heads, use good quality video head cleaner in your camera and clean video head. Problem will be resolved.
Nov 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
i suggest you insert a head cleaning casette to see if this removes the lines.the lines occur when one of the heads is dirty or not operating. if this does not solve the fault then the head might need changing.
May 27, 2008 | Panasonic PV-GS35 Mini DV Digital...
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Open Questions:
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
32 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
