Question about Zebra LP 2844 Thermal Printer
I have a Fedex lp2844 Zebra Printer, It seems like it will only print FedEx Waybills. Is there a way to kind of unlock it, so I can print ups/purolator waybills to?
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
SOURCE: Zebra LP2844 Thermal Printer won't print from a browser
I posted this problem last week and since that time discovered the problem (at least for me). I had to replace the HD and failed to update a current version of Java. Without Java in place I could call for it to print but the print job would disappear into thin air. After installing a current version of Java the machine began printing again and has worked perfectly.
Posted on Apr 28, 2009
  • 185 Answers
SOURCE: My Zebra LP2844 will print fine from Zebra
If you are printing through a driver the raw output will be converted and printed. Please make sure you have the correct driver installed.
To send a single command can be sent via the Driver, right click the driver and select properties. Go to the Printer Tab and select Advanced and then "Tools". Click the Tools button and there is a dialogue box available to send commands directly to the printer.
Posted on Oct 29, 2009
StampsCom
  • 3 Answers
SOURCE: No option to use with Stamps.com
bacpro,
The Zebra 2844 is a printer that is supported by Stamps.com. Because there can be a number of different issues when setting up a new thermal printer, we will be able to best assist you over the phone; it looks like you are already planning to call us. For your reference, here is our support information:
Stamps.com support is available toll-free at 1-888-434-0055, Monday - Friday, 6 a.m. - 6 p.m. Pacific Time.
Chuck
Stamps.com
Posted on May 17, 2010
Testimonial: "Yes, this helps, however I call Stamps.com & they advised me. They told me that I had downloaded the wrong driver. I needed the Universal driver. I got the correct driver & it worked. Thanks John"
SOURCE: zebra lp2844 printing incorrectly with paypal multi order
Anyone solve this problem?
Posted on Sep 03, 2010
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
How do I get Fedex label printer to print from other programs??
eack software have diferent wais to talk with the printer,
or send the comands to the printer (zpl files) and like this, he can send the printer configuration direcly, or can use setings from the driver.
if you go to Printer and Fax, right click on the printer driver, go to "properties" and print the test-page.
If print text plus the windows logo, that meens the printer is comunicate, now the rest is with the each software.
Nov 12, 2010 | Zebra LP 2844 Thermal Printer
I am having the same problem and it is bugging me. I can print the test page through printer configuration but it will not allow me to select the thermal labels in stamps.com!
May 04, 2010 | Zebra LP 2844 Thermal Printer
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Jan 14, 2009 | Office Equipment & Supplies
Wont print
Check to make sure you have direct thermal labels. You can test this by scratching your fingernail across the label quickly. You should see a black line. This printer uses the same paper as a ups or fedex label. test a ups of fedex label with the fingernail test. Does it look the same? or call Andrew @ 908-725-1699
Jun 17, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
266 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
