Question about Toshiba 50HPX95 50 in. Plasma HDTV
My toshiba 50hpx95 plasma tv makes just a clicking noise from the relays on the power supply but nothing else wont power on and no lights flashing
  • 144 Answers
A common problem with modern power supplies is dryed out capacitors in the power supply, This pulls down the voltage and shuts down the tv. The can usually be spotted if you know what to look for (they swell up and deform a little). It is not a job for the novice. But capacitors are cheap.
Try a local tv shop for estimate
pete
Posted on Nov 08, 2010
  • chrisboy598 Nov 08, 2010
    yeah i checked for swollen capacitors but no luck all of them look normal
I have a Toshiba 50hpx95 plasma tv with a blinking red light. I have already replaced the power supply board and the problem is still there. I need help
I'm no TV expert, but I can share what little knowledge I have, specially what I went through with my plasma TV. It happen in mine, and I got the Y Board fix. When mine was blinking, there was no power, but it wasn't the power board, so searching for an answer in the internet, I found out that it could be one of the boards (Y board or Z board) In my case was the Y board, so I took it to a professional and he fix it for me. IF possible search for: How to troubleshoot TV Y Board.
Mar 02, 2015 | Toshiba 50HPX95 50 in. Plasma HDTV
My toshiba 50hpx95 has a steady blinking red light, it has no pauses or breaks to recite a code, just steady blinking. I had it in the shop and they said the power board needed replaced, so i replaced it...
This tv have a Tuner signal board it is also dead too,this problems happen sometimes,the power supply board dies,but sometimes the Tuner signal board take power surges from the power supply board itself than kiill the tv Tuner signal board too.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.Fixed this problems,many times before.Blinking power LED light.First replaced the power supply board,than didn't solved the problems,than the tv Tuner signal board it is also dies too.
Mar 16, 2011 | Toshiba 50HPX95 50 in. Plasma HDTV
F;lashing power light red, tv wont turn on even after unplugging still wont come
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 27, 2010 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50HP95
I would contact guy at
plasmatech@gmail.com
he has great expertise and all parts for Toshiba Plasma TVs
Jan 08, 2009 | Toshiba 50HPX95 50 in. Plasma HDTV
How to bypass seine card? 50hpx95
Turn off set, unplug power. Remove back cover. On brown circuit board left of center, unplug connector PJ63A. Plug in power, but don't electrocute yourself! If you no longer get the continuously blinking red light, hit the power button. If it comes on, the SEINE module is bad and must be replaced.
Dec 13, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
50" toshiba plasma
The only thing I can think of that moves to make noise is the cooling fan is squeaking for some reason if you are able to remove the back of your TV look to see if your fans are clogged with dust and clean them if they are
Nov 04, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Red light flashing. TV wont start.
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
Sep 26, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50in plasma
Hello brattbabie1,
Ok you have sound and no picture. This denotes that since this is a plasma TV the circuitry that controls the activation of the screen may have become defective. You will need the schematic to show the voltage levels that need to be present on the cable that connects between the screen and the control circuit and a voltmeter to measure those voltages. I would suggest that you get a qualified TV technician to work on this problem, due to the technical nature of this issue.
I hope this helps,
Thank you,
Shuttle83
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50 inch plasma
Hello BlufftonT,
This is an indication that there may be a problem in the power supply, possibly bad capacitors, and or defective active components. I would suggest first checking to see if there are any blown fuses, and or loose connections. Past this point I would advise that you either take the TV to a TV repair shop or have a TV technician troubleshoot the TV in home to determine the problem it is having.
I hope this helps,
Thank you,
Shuttle83
Apr 01, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50hpx95
How much electronic or solid state repair experience do you have. Can you read a schematic and follow circuit flow from one circuit to another? Do you know how to use a multimeter? If you say no to one of these, this is not the repair for you. If you say yes, send the service manual to techman32k@yahoo.com and I will take a look. Good Luck
Oct 16, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 50HPX95 50 in. Plasma HDTV Logo
400 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
