Question about Dell Inspiron Mini 10 Notebook
Dell inspiron mini battery can not be identified system will not charge
SOURCE: Cannot identify Battery
Hi
Please update your system using this file and if this does not work try to reseat the battery and check.
If you are using vista download the file to desktop. Right click. Click on run as administrator. Let me know if this resolves your issue or you need more help.
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=264350
Thank you
Rakesh
Expert Dell Laptops.
Posted on Jan 06, 2009
  • 3940 Answers
SOURCE: BATTERY CANNOT BE IDENTIFIED
Generally this is an indication that the battery has failed. The normal life span of a PC battery is 300 to 500 recharge cycles (Roughly 12 to 18 months) so the most likely answer is buy a new battery since this one is already out of warranty
Posted on Jan 27, 2009
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
Posted on Jul 31, 2009
buffalonyman
  • 1865 Answers
SOURCE: Battery won't charge (Dell mini 9 Linux).
The software has nothing to do with the charging system. There was a recall on some batteries, and that may be why they issued replacements.
Posted on Sep 13, 2009
SOURCE: dell laptop cannot identify battery
Update the bios. I did it and problem solved.
Posted on Oct 29, 2009
Help me with my Dell Inspiron Mini 1012. It won't turn on, i tried taking my battery out and only AC adapter attached, but the power indicator lights steady Orange.
Check its battery for full charge. Charge it fully overnight and check. Check the voltage of the battery too. This is a battery related problem. Electro help
Oct 03, 2014 | Dell Inspiron Mini 1012 Netbook...
Will not recognize battery
Is it a Dell battery or OEM? If it is an OEM it may be designed to ignore it and only use Dell type batteries. Or, is it very well used? It may be faulty.
Nov 30, 2013 | Dell Inspiron Mini 1012 Netbook...
I plug my laptop in and it comes up on the screen, unable to identify battery, but has a full charge? Why?
All dell batteries have a small chip in them. Basicly Dell has determined that your battery has reached the end of its useful service life compared to other batteries that it has tested.
This is compuletely normal for dell computers. Now if your computer is still within the warranty period they will send out a new one free of charge.
To find out if you have remaining warranty, go to dells warranty page here. On that page you will enter your service tag # that is found on a thin white sticker on the back of your computer.
Hope this help.
Feb 20, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell inspiron mini 1011 netbook, only had it a year, was working fine last night now it says "the battery cannot be identified, it cannot be charged on this system." The light keeps flashing...
Take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Aug 26, 2010 | Dell Inspiron 1011 Mini Netbook (Pink) ...
How can i fix my new dell netbook inspiron mini 1010,when i turn it on there is warning that the battery cannot be identified.the system will be unable to charge this batt
Try to unplug the battery and plug it back well.
Does your battery's power ratings match with your Laptop? Check that information just on your battery, power adapter and on the laptop. If theres any mismatch, please get what matches your laptop.
Otherwise check whether your Power Adapter charges your Battery (Test for power within the Charger). If everything fails, change your battery and ensure it fits your Laptop in terms of Power ratings.
Good Luck!
Jun 24, 2010 | Computers & Internet
What is procedure to recharge the battery on a dell mini 10
When the AC adapter is connected to the system (Either running or off) the battery should charge.
Sep 25, 2009 | Dell Inspiron Mini 10 Notebook
I just put a replacement battery on my Inspiron 710M. On startup I get a message that says, "The battery cannot be identified. This system will be unable to charge batteries until this battery is removed."...
This battery is not compatible with this laptop. Dell batterys have a sensor that tells to laptop is it dell battery or not. Unfortunately you have to replace battery with correct one.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
When I turn on my Dell Inspiron 1501 laptop, I get this:
Warning: the battery cannot be identified.
This system will be unable to charge this battery.
Press Any Key to Continue.
Press <F2> 2 times to enter SETUP.
Press <F12> and Any Key to enter Boot Menu.
what should i do?
Jan 06, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron Mini 10 Notebook Logo
1,841 people viewed this question
Alun Cox
