Question about GE Spacemaker JVM1640SJ Microwave Oven
How do I replace door handle on GE Spacemaker XL Model# JVM1339BW002
  • 1 more comment
  • Dan Davis Davis Nov 08, 2010
    Do you have a diagram you can send me?
  • Dan Davis Davis Nov 09, 2010
    Daniel,
    I have been able to access the holes for the screws to hold handle in place. Next problem...The bottom screw is missing. No screw in my area and 2 weeks to order. Do you have the dimensions of the bottom screw? Can I just buy a similar screw at ACE or Home Depot that will fit without causing any problems?
  • Dan Davis Davis Nov 10, 2010
    Got er done
  • 4,323 Answers
Hi
Use 2 putty knives to remove the inner plastic frame or seal. There are 2 screws that are accessible and can be removed easily. Remove the glass front panel to get to the remaining two screws. To remove this you'll need to unscrew 6 small Phillip's screws. Now dislodge the clips to remove the top and bottom. Now you can access the remaining 2 screws, replace the handle and assemble in reverse order.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Nov 08, 2010
  • 1 more comment
  • Daniel Scott
    Daniel Scott Nov 08, 2010
    Hi
    Please check the below diagram---
    Daniel
  • Daniel Scott
    Daniel Scott Nov 09, 2010
    Hi
    You can buy these screws from this link---
    Daniel
  • raiftodd1 Nov 28, 2010
    GE usually hides the parts info and wiring diagram in a envelope inside the cabinet on the left hand side alone with instructions on how to replace the door...
I need the specs for GE Spacemaker XL JVM1339BW002 and need to know since I am replacing this unit w/another GE what type of venting do I need, and will I need to purchase a new trim kit?
The GE Answer Center can answer those questions. 800.626.2000
Give them your full model number.
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for more free help.
Nov 26, 2016 | GE Microwave Ovens
How do you remove and then replace the handle on microwave model JVM1339BW002
Open the door and you'll see a plastic frame that goes around the inside of the door. That has to be removed VERY carefully by prying it out.It breaks very easily. I use a putty knife. When thats off you will see two screws that hold the handle in place.
Nov 11, 2011 | GE Microwave Ovens
The door handle on my GE spacemaker xl 1400 microwave is broken (plastic). How do I fix this.
By replacing with new one for sure... You can find them on amazon, here: Amazon com ge spacemaker xl handle. I hope this was helpful. Cheers
Nov 14, 2010 | GE Spacemaker JVM1740 Microwave Oven
I need to replace a broken handle on a spacemaker xl 1800 I have the handle, just don't know how to take the door apart to fix. Is there a website with directions for dummies :) Thanks
You have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Aug 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to Replace Spacemaker XL door
i'm also looking for an answer.
Thanks
Mar 15, 2008 | Microwave Ovens
Microwave Door Switch Problem?
That model number has too many digits after the JVM. Could it be JVM1339BW02 or JVM1339BW002?
If one is bad, it's probably the bottom switch, whose wiring goes back to the power relay, thermostat, or fuse, depending on eact model.
The switch with thin wires going to a ltitle connector on the board is the door sense switch. That's not likely your culprit.
I usually recommend you replace them all while you're at it.
It sounds like it may actually be a loose or misaligned door or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
GE models have a very helpful "mini-manual" hidden inside the unit behind the control panel. Handy in troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
641 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
