Question about KitchenAid Dishwashers
I have a KUDK01IL or KUDL01IL that I purchased in 2003 and it went from quite to a very loud wash. Now the dishwasher is not working. Is the motor gone or is something preventing the motor from "kicking-on?" There is water and heat and pannel lights work. Appreciate your help to let me know if this can be repaired or if I should buy a new machine. Thanks.
  • 1019 Answers
SOURCE: Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Posted on Feb 28, 2008
SOURCE: kenmore elite dishwasher making loud buzzing sound when washing
I had the same problem with by Kemore Ultrawash after two years. The motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. I was surprised how easily the motor came apart from the dishwasher, a good design. The motor has three screws that holds it together, I took them out and took the motor apart.
I took the old beaing off the shaft with a grinder, careful not to groove the motor shaft. I did, but just put some high temp silicone caulk in the groove before I put the new bearing on the shaft. I bought a new bearing on the internet, it is a 22mm x 8mm x 7mm. I bought one that went in a small engine, a quality one. I placed it on the shaft, put the motor back together and put the dishwasher back together. It has run quiet and great for many weeks now. I expect the dishwasher may last many years now, because the bearing I took out was a cheap aftermarket one, and the new one is vastly superior in quality.
Good luck and fire away with any questions. I love this dishwasher and am glad I could fix it for 19$ and some of my time.
Posted on Nov 08, 2008
  • 338 Answers
SOURCE: Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Posted on Nov 25, 2008
SOURCE: LG dishwasher doesn't heat water
I had the same issue with my LDF7811 about 2 years into its life. I replaced the heating element and that took care of it. Not a terribly difficult job, but it will require removal of the dishwasher and dismantling it from the underneath.
Posted on Dec 18, 2008
wolfpackicu
  • 26 Answers
SOURCE: Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Posted on Jul 30, 2009
Hi our dishwasher fills with water and then never kicks into the wash cycle. It shows wash on the panel but hums real loud. We did replace the water inlet valve thinking that was the problem even though at...
Hello, it sounds like your dishwasher motor is bad. These frigidaire motors go out quite frequently. To replace it, pull out dishwasher and underneath, just disconnect the mount and screws and it'll pop right out. You can probably get a motor online for 100 bucks. Hope this helps,
Rich
Western Appliance Repair Meridian
Dec 01, 2010 | Frigidaire 24 in. FDB126RB Built-in...
After it fills with water and starts washing it makes a loud buzzing sound. What is the issue and how can I fix it?
Hi- Please provide make and model number. It is probably an issue with the motor or circulation pump depending on what type of machine it is. If it is washing ok but just noisy (some motors get very loud just before they quit) often it is not worth putting a lot of money into it as motors can be expensive. Especially if it is an old machine.
Sep 24, 2010 | Dishwashers
Newer dishwasher and actuaslly says in manual do not be alarmed if you cannot hear dishwasher as it is very quiet. Well mine is the exact opposite. It is so loud. Sounds like the motor is in overload....
I would suspect there is something stuck in either your wash motor or drain pump. If the noise happens throughout the whole cycle, it's likely the wash motor, but if it only happens on start up and periodically thoughtout the cycle, it's the drain pump. The drain pumps are known however to get noiser after a few months, in which case I would have the drain pump replaced.
Apr 07, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Whirlpool GU1500X dishwasher motor noise got loud
Hello- Yep- it's toast. A small seal on motor shaft failed, causing water to destroy bearings. Motor is about 100$. Installation instructions available if you choose that route. Let me know if this info helps- have more if needed.- Thanks - Ed
Mar 12, 2010 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwasher making loud noise during wash cycle
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
thanks and accept the solution accordingly
Apr 03, 2009 | Kenmore Dishwashers
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
Kenmore elite dishwasher making loud buzzing sound when washing
Oct 08, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Aug 18, 2007 | Bosch 24 in. SHX33A02 / SHX33A06...
Loud Whining/Humming noise while washing
Water-inlet valve
Motor
Heater fan
Pump
Feb 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
94 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
