Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi iz 16, P6749639 stops in the middle of spin circle
The machine has been working fine, until yesterday when I put on a cotton quick wash (1h). After 43 min, in the middle of spin circle it cut out and made the split load switch in the fuse box go off. When I switched the fuse box on again, the machine cut out after 2 secs again. I took the washing out and drained it manually. Then I tried it again with no clothes in it, and again it cuts out at the same place in the circle. It spins and drain fine earlier in the circle, before cutting out. What could the problem be?? Thanx, Moa
5 Suggested Answers
SOURCE: Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Posted on Jun 28, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 84 Answers
SOURCE: i have a zanussi zwf1432w washing machine and it
Powercuts and power surges do sometimes affect electronic controls.
Posted on Nov 11, 2009
beltronic205
  • 1474 Answers
SOURCE: Hi i have a zanussi
Okay .First you need to say if the pump is working or jammed if you have cleaned the filter then its possible the pump needs replaced......
Posted on Jan 08, 2011
How do you remove the lower front cabinet plinth on a Zanussi IZ 16 S washing machine?
Why? If I remember correctly behind the plinth do not have access to anything. If you need to replace the drain pump or filter housing you can access from the bottom or open housing of washing machine. This washing machine has a housing split into two halves and afterwards you will have access to almost all components of the washing machine.
If you need to replace just plinth, may help this spare part list.
Dado
Feb 19, 2017 | Zanussi Washing Machines
My Zanussi FJD1666w spin cycle isn't working. Any ideas?
Machine spins but stops.. loading imbalance.. try with less load.. or drain pump and valve not working.. check for block..
Jan 26, 2015 | Zanussi FJD1666W Front Load Washer
Have just bought a zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away. Is this because it was a quick wash? V disappointed as I need a...
zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
Feb 15, 2011 | Zanussi FJS1225W Front Load Washer
Hi I Have a IZ 161 W goes through all cycles until spin starts in slow spin but thats it and the time does'nt move basically it is not spinning to full speed . appreciate any advice regards Sarah
The speed of spinning in the washer depends on the weight of the linen in the machine. if the machine is not fully loaded it will create an inbalance and the motor control unit will sense this and hence spin at a low speed. Solution is to ensure that the machine is fully loaded with enough linen.
Oct 05, 2010 | Zanussi IZ161W Front Load Washer
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
Washing machine wont go from wash to the spin etc automatically
Do not fool with this you will void the warranty, you have a defective machine, contact the manufacturer.
Apr 17, 2017 | Whirlpool GHW9400 Front Load Washer
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi iz 161s
e10 indicates a problem with water supply
Oct 12, 2007 | Zanussi IZ161S Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
