Question about Samsung NV3 Digital Camera
SD CARDS!!! So I've had my NV3 for a while now and I'm now thinking I should get a bigger SD card for it because i'm going away for a month...the first card I got was a SanDisk 2gb and it's been perfect no problems whatso ever. Now I've just bought 2 Transcend SD cards both 4 gb and when I put them into the NV3 it just says memory full when it's completely empty! I've already sent back a SDHC card and don't want to send these back, does anybody know whats goin on here? HELP PLEASE!!
    Guru:
  • 1,894 Answers
Dont go for more than 4GB it makes ur unit slow
Posted on Jun 16, 2008
My camera is saying memory full with a new sd card in. why?
The Samsung NV3 can only use standard SD memory cards up to 2GB. I'm guessing that your new card is a 4GB SDHC card, which the camera is not capable of recognizing. Fortunately, 2GB SD cards are relatively inexpensive these days, and are widely available on Amazon (see this link) if your local store no longer carries them.
Oct 08, 2011 | Samsung NV3 Digital Camera
New 4GB SDHC mamory card will not work in my Samsung NV3 camera - I get a memory full message. I have formatted the card and erased internal memory with the card out of the camera and still no joy - any...
Sorry, but your older camera can only use 2GB or less standard SD cards. Fortunately, these are relatively inexpensive these days, and may be found on Amazon, if your local store no longer carries them.
Aug 15, 2011 | Samsung NV3 Digital Camera
Hi. I've got a vivitar vivicam 4000 camera. But
The absolute largest capacity SD card which your camera can use is 512MB. Your camera is only a 6MP model, so that size will still hold plenty of images even at the highest recording quality settings (approx 183 images at 6MP Fine quality setting, 311 at 6MP Normal quality and if you dial it down to 4MP you're looking at 305 and 498 respectively. 4MP will still produce perfectly good image quality for prints up to A4 size).
You can no longer easily find SD cards of that low a capacity in most shops, but they are widely available online. As you can't wait that long, I suggest that you join your local FreeCycle group and post a request for one (your first posting must be an offer, but it can be for anything at all, and once posted you can immediately post a request). Plenty of people have obsolete cameras lying around and even stacks of old low capacity memory cards which they are often happy to give away.
You can also download a free .pdf format user manual by clicking here, courtesy of Retrevo.
I hope that my speedy, free, and comprehensive reply has been of use to you, and that you can take a moment to rate my answer.
Jun 18, 2011 | Vivitar ViviCam 4000 Digital Camera
Nv3 it says memory full even if the sd card is empty. it wont take photos
try using the camera to reformat the SD card.
Or maybe if that camera has internal memory, it is set to use the internal memory. Go to the options and set the camera to use the SD card
Mar 03, 2011 | Samsung NV3 Digital Camera
Sdhc card used in samsung nv3 it says memory full
I don't think that camera (the Samsung NV3) takes SDHC cards. The same is true of many (perhaps most) cameras that were released more than a year or two ago.
You need to use a regular SD card, which -- as you probably know -- isn't any bigger than 2G.
May 20, 2010 | Samsung NV3 Digital Camera
Full Memory with new cards
Go into the camera setup menu and make sure you have it set to save images on the card, instead of internal storage.
Dec 19, 2009 | Samsung NV3 Digital Camera
SD cards
Do the 4GB Cards say SDHC on them? They should. SDHC is simply "Secure Digital High Capacity". They're high capacity SD cards that hold more than regular cards. In this case, 4GB. The problem with these is that they need to be supported by the device. I've never put an SDHC card into a device that doesn't support them, but it looks like that's what your situation is. The highest memory capacity a non-SDHC compliant device is capable of 2GB. I recommend that you return the 4GB cards and buy 2GB cards instead.
Jun 16, 2008 | Samsung NV3 Digital Camera
MEMORY FULL
How many photos or videos do you have on the camera already? It probably won't store more than about 4 shots.
May 04, 2008 | Samsung NV3 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Samsung NV3 Digital Camera Logo
153 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
