Question about Microwave Ovens
Whirlpool microwave model # MH6150XLQ
DOES THIS MODEL HAVE AN INTERNAL FUSE? IT STOPPED WORKING AND EVEN THE LIGHT DON'T COME ON.
I CHECKED THE BREAKER, I CHECKED THE WALL RECEPTACLE (OK)
CAN'T GET POWER TO MICROWAVE
  • 5,911 Answers
Yes, there is. If you go to searspartsdirect.com and type in your model number, you will find the fuse listed under the "Interior Parts" heading as item number 14 (part #815174). You can find appliance fuses much cheaper at the local hardware store. Just make sure it is the correct type and rating (refer to the fuse in the appliance for the information - these are usually a 120V 20A fuse). The reason I mention this site is because they provide excellent part drawings and provide part numbers. There should also be a wiring diagram located behind the control panel to assist you in troubleshooting. Please go to my profile and use the "Ask Me" feature if you require further assistance. I hope this helps you.
Posted on Jun 16, 2008
My ge microwave spacemaker profile model # JVM1860BF001 stopped while in use. Interior light, clock and timer work. Door vent opens. turntable doesn't work. Won't heat.
check the breaker, or check if the wall socket works. If there is power, then you need to take it for service. There are no user service options for microwaves as they are so dangerous for both super high voltage and also microwave emission. Some models do have a pull fuse on the rear, so check for that first.
Oct 04, 2016 | GE Microwave Ovens
Put something to heatup after pushing start made standard startup noise then abruptly stopped working even electronics....breaker fine and receptacle working....does this unit have a fuse??
Almost all microwaves have internal fuses. Counter top micros need to remove outer case and fuse should be near where power cord enters the microwave, Fuse looks like old style glass car fuses but is white or gray ceramic. Can't look at it to tell if its bad. Need tester. Over the range (wall Micros) usually have the fuse directly behind the control panel which you will need to drop down away from the body. Same type fuse as stated before. 15 or 20 amp should be stamped on metal edge. Purchase at Radio Shack or a parts store---or some Hardware stores.
Mar 31, 2015 | Microwave Ovens
Replace the plug on microwave/convection oven
You will need a heavy duty 3-wire power cord rated at a minimum of 15 Amperes and 20 would be my choice.
Microwave ovens can draw well over 10 Amperes alone and having an additional heating element will raise the current consumption further.
Hopefully the circuit being used has a circuit breaker rated at 20 amps too.
Voltage rating is less important and any you find will be OK at 120VAC and likely hundreds of volts more.
Also, inspect the receptacle too; if the plug shows signs of heat damage, this can be caused by a bad wall receptacle.
Look around the cover plate on the wall for any signs of discoloration.
This is a sure sign of potential internal damage and both must be replaced to prevent a fire.
Feb 10, 2015 | Microwave Ovens
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
I have an LG LMVM2075ST which has worked flawlessly for 5 years. It just stopped working. No lights. Checked breaker, checked outlet, unplugged - plugged back in ... now at the point of troubleshooting...
Unless you are good at this troubleshooting, with a multimeter, circuit diagram, and so forth, I'd take it to a service tech. You may find that a quote will approach the cost of a new one, or that parts are not so easily obtained now.
I'd say a fuse has blown or thermal cutout failed, if everything is dead.
You should be aware that the magnetron circuit in these things generates a lethally high voltage which can be present even when unplugged from the wall.
Sep 14, 2013 | LG Microwave Ovens
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
I have model RCS10DA two and a half years old and gets considerable use. Stopped working. Has power at receptacle. Are there any internal fuses. what should I check first.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 16, 2011 | Amana Microwave Ovens
No power or functions of any kind.
Check the external fuse / circuit breaker first.
IF that is OK, then it's possible an internal fuse has blown. These can be replaced but it should only be attempted if you are confident enough to be able to discharge and ground the main capacitor before working on the device.
Mar 23, 2010 | Whirlpool GH4155XP Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
437 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
