Question about Dell NVidia Geforce2 MX400, (64 MB) Graphic Card
H orizontal coloured lines on screen at all times on every window On E Mail screen and light backgrounds the fault appears.asYellow horizontal.squares across the screen & the Mouse curser has a small square halo around it I. have not yet tried to fix it..
    Guru:
  • Dell Master
  • 1,705 Answers
It could be either you card or your monitor, as its easier, swap monitors first, if the problem prevails then you probably need a new card, second hand replacements are fairly cheap on ebay or PC repair shops.
Posted on Nov 08, 2010
Bravia KDL46w5500. Why does it display vertical lines all over the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 30, 2015 | Sony Televison & Video
Flashing background
On a Windows 7 system, right-click on a blank area of the sceen, click on Personalise at bottom of menu and select whatever theme or picture you want as the background. It is slightly different for other windows system, but you should start with right-clicking on a blank part of the screen..
Jan 30, 2012 | Samsung N150 (36725723009) Netbook
A thin horizontal black line has appeared just below the centre of the screen on my hp pavilion dv6000 (running vista), there is no change when i gently press the screen, so i think the problem isnt with...
As the symptom you indicated above it is the problem with your LCD Panel. It is to be replaced to sort out this issue. To check and confirm the functionality of your Laptop motherboard plz check the Laptop with external display.
Nov 25, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Outlook express 6: How do I increase the window size of the select recipient window? Somehow after another used my PC; the window now opens too small.
Guide slowly the tip edge of your pointer over the orizontal line at the bottom of your recipient window and an arrow with 2 points will appear. Press your right button of your mouse and push it downwards to enlarge the window.
Oct 28, 2009 | Microsoft Windows XP Home Edition
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Text background colour for icons
go to system properties-appearance-icons-change background color as you desire
Nov 28, 2007 | Microsoft Windows 2000 for PC
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Dell NVidia Geforce2 MX400, (64 MB) Graphic Card Logo
163 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
