Question about Honda Garden
Have a Honda Excell VR 2522 pressure cleaner and need new tires, help !!!
    Scholar:
  • 100 Answers
If they are the tires with the plastic rims then there was a recall and a local service center can replace them for free, if not I have tires that fit on this unit in stock, price is $13.33 each, send me a email at justin@wmpcs.com
Posted on Nov 09, 2010
Excell xr2750
excell does NOT make the engine. telling us the engine information might help better but RARELY is it a timing issue. check for spark, if you have spark then shoot carb cleaner into the carb... does it start ???
Nov 27, 2013 | Garden
Where to install thermal relief valve
It should be the last threaded hole right before the water enters the pump itself, on the low pressure ( inlet) side, most pumps have 2 different size holes 90 degrees from each other, commonly 1/4 and 1/8 in.
Dec 13, 2012 | Honda Karcher G2400HH-R Pressure Washer
My Honda VR 2522 Pressure washer went unused for approx 16 months. Now I can not get it to start. What can I do to start it?
There is little doubt that the problem was caused by old gas. First you will have to drain the gas. From here you have two options.
1. Remove the carburetor and clean it and put a new kit in it.
2. You can try what I call hand choking the engine/carberator until it sucks the old junk out of the ports in the carburetor. To do this you will have to fill the tank with fresh gas. Then remove the air cleaner, block the intake opening and crank the engine. A small spray of starting either from time to time can help speed things along. You need to block the opening tightly. Do not use anything that can get sucked into the engine if it tries to start. Occasionally unblock the carburetor and crank the engine, this will give the engine some air to breath. You may have to repeat this numerous times until fuel starts moving freely through the carburetor. Once it starts and runs as it should don't forget to reapply the air cleaner.
If #2 doesn't work, you have to revert to #1.
Feb 27, 2011 | Garden
My Honda Excell 2400 psi EXH2425 pressure washer starts and runs pretty smooth but I can't get very much pressure in the spray. I have used carburator cleaner and the air filter looks alright, aside from a...
It sounds like the unloader on your pump is going bad but it is hard to say if it is that or the valves in the pump. The only issue with this machine is that parts are no longer available for this pump. The only option I really have for you is to replace the pump with a new one, it is a very simple process and only takes about 15 minutes to complete.
See this link for information on the pump that would fit your machine
The only thing else you might need is a coupler to have the hose adapt onto this pump
See this link for the coupler
Nov 12, 2010 | Honda Garden
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
Excell pressure washer honda motor---have fuel flow---fresh---only runs when carb cleaner sprayed--then dies..........
Sounds like the carb is badly clogged internally. If you can remove it yourself, you can soak it overnight in a can of carb cleaner. But keep in mind some of the internal passageways in the carb are as fine a human hair and soaking may not work, it which case go to plan B, new carb. Last resort you could try to find cleaners small enough to get in the passageways of the carb, I've heard of people using wire brush bristles for example. Today's gas is terrible, it does not take long to gum up the carb, if it sits for any time.
May 01, 2010 | Karcher 2500 PSI Pressure Washer
I have an Excell Pressure Washer Model VR 2522, it is leaking from the botttom but can find its exact location of the leak, have all the part but can't find the leak and don't know what area it's leaking...
Hi and welcome to Fixya. Your model has the A14527 Pump assy on it and they are notorious for the pistons leaking due to blow by and the 16 MM seal on the piston starts to leak near the drive shaft.
In addition the O-rings #2950 that mated the piston housing leak. Add to that the 4 o-rings that mate the pressure head to the pump also leak.
See this manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/A14527/A14527.pdf
There are a BUNCH of parts in this pump. One mistake and it will not work when you get done working on it. Be careful what you disassemble.
The seals that leak are items 4, 15 and 16 in the manual.
There can be other leaks.. the ones I pointed out are the most common.
Thanks for using FixYa.
Kelly
Apr 13, 2010 | Garden
I just bought a 2nd hand honda excell psi max vr 2522 2.2 gpm max 5.5 hp gvc160. i put gas and oil and it wouldn't start?
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Sep 25, 2009 | Karcher 2500 PSI Pressure Washer
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
322 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
