Question about Air Tools & Compressors
Hi! I have a compressor that leaks air on the bottom of the tank. I neglected to drain it during it's life time, so it got rusty at one spot and, when I pump air, it leaks. Is it repairable? Could any patch be welded, or something else?
  • 885 Answers
Due to the explosive ability of compressed air, I would not recommend any repairs to a compressor tank. It is possible to weld a patch on the rusty spot but the heat would weaken the rest of the tank and you could face a very dangerous explosion if the tank should fail at another spot. As an authorized service center, if I have to replace an air tank I have to drill holes in the old tank to render it useless and safe. Save yourself a huge nightmare and buy a new compressor.
Posted on Nov 08, 2010
Testimonial: "Thank you very much! That's what I thought myself, but still was hoping that some miraculous solution might exist :) I'll make sure to get rid of it!"
What causes air compressor to continue leaking air
A hose connection, such as a hose end coupler for
your tools,etc They get rusty inside & only last about a year
Next would be any threaded connection,mostly hose & regulator or filter related
Then you have the air tank check valve leaking or the drain valve
on bottom of the tank
Jul 14, 2014 | Ingersoll Rand Air Tools & Compressors
Air releases from the bleader valve as soon as i turn the unit on and continues to releaseis this normal?
No you need to simple tighten the bleeder valve on the bottom of the tank. Its there to release moisture and manual says to drain after each use. I drain mine weekly if I've been using it. It prolongs tank life by preventing rust.
Feb 25, 2014 | Husky Portable Air Compressor: 20-Gal....
Husky air compressor
Josh:
Your compressor shouldn't run more than ten to fifteen minutes before shutting off. The pressure should be posted on the machine somewhere ( a decal usually says xxxpsi). You evidently have an air leak somewhere. On the bottom of the air tank there is a valve for draining the tank of air and any moisture. Make sure to close that valve by hand only (Screw it in all the way by hand and remember, you are working upside down, so don't get confused as to which way to turn it). If the valve will not unscrew to drain the tank, you can use a pliers to loosen the valve to let the air out, but be sure you are turning it in the correct direction or you'll break the drain valve!! Now that you have the drain valve closed, turn the compressor on and watch the pressure gauge. When the pressure gauge reads the pressure on the decal, the machine should turn off. If the pressure gauge stops climbing before it reaches the specified pressure, you have an air leak somewhere. You can either feel for the leak at the air line connectors by hand or mix a dish soap and water solution the pour on the air line connectors to look for the leak. Keep the soap solution away from the motor!! When you find the leak, drain the tank using the drain valve at the bottom of the tank, disconnect the hose coupling that is leaking and wrap Teflon tape around the threaded portion of the male end of the fitting (3 wraps should do it) and reconnect the coupling ( tighten it well). Close the drain valve and start the compressor again. and check all fittings for leaks again.
Jun 04, 2013 | Air Tools & Compressors
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
I have a 2 gallon compressor , no air comes out?
Check if air intake is clogged.
Check if drain valve on tank bottom is open or closed.
Look at pressure gauge and see if pressure is zero.
Adjust pressure so tank will hold 80-120 psi.
Check air lines between compressor and tank to see if they are leaking. Listen for leaking air while motor is running.
Jun 24, 2012 | Campbell Hausfeld Air Tools & Compressors
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
Pressure of the air compressor does not go above 1 bar
Check for a fitting on the bottom or end of the tank. This fitting is used to drain air when not using the compressor for long periods, and should be left open most of the time. The biggest reason is that compressed air contains moisture...which will eventually rust your tank. Opening the fitting allows the water to drain out.
Since you have 1 bar, it's probably on, but loose.
Otherwise, feel for air leaks.You may try brushing on some water and dish soap...the leak will cause bubbles.
Good luck.
Feb 04, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I Have a Stanley air compressor Bostitch model APC-OL6-UK it is spitting brown liquid how do I clean this please
The brown liquid you are getting out of the compressor is water with rust in it from the inside the air tank. Somewhere on the bottom of your air tank there is a valve you need to open from time to time to drain the water from your tank. If you are getting rusty water from the air outlets you probably have a lot of water in the tank. If you can take the compressor outside, with pressure in the tank, where the water won't stain anything and slowly open the valve to drain the tank.
Feb 02, 2011 | Stanley Air Tools & Compressors
The preassure only gets to about 50lbs. on my 2 Hp 4 Gal. compressor and the motor just keeps running. Is my compressor going bad or is this something that is fixable?
Hi, my name is John. Welcome to FixYa. You are loosing pressure somewhere. Check for air leaks in the lines, check the line coming from the pump to the tank, check the drain valve at the bottom of tank. Thanks for choosing FixYa....John
Nov 17, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Moisture is coming through my air compressor hose and into my airbrush gun, resulting in splats. if i press the gun for air moisture (water) still comes thru. when the gun was removes the moisture was felt...
When you compress air the moisture in the air condenses and pools in the tank, all compressors do this whether new or old. If there is water built up in your the tank it will come out when you release the air. There is a valve on the bottom of the tank you have to open from time to time to drain this water from the tank. Take the compressor outside if possible or have something under the valve to catch the water as it comes out. Open the valve slowly or it will blow the dirty/rusty water all over. Campbell Hausfeld and some other companies make filter/driers to put on your supply line if the air needs to be dry for your use. Most box stores (Home Dept, Lowe's, etc.) carry these driers or can order them for you.
Oct 31, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
176 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
