Samsung le37r8 factory reset code, does anyone know how to reset tv to factory default, i have a channel locked on tv and can';t do anything
SOURCE: samsung tv le37r8
Using a monitor
1..connect computer/media center to your monitor,
2 click on nvidia nview display settings,
3, select the current display tab and samsung,
4 then apply,
5,then when the confirmation box appears click yes within 15 seconds.
Using your samsung.
Attach a scart to your media centre, from your t.v with the p.c cable still attached, turn over using the source button until you can see a pc picture on your screen (EXT1or2), do steps 2 & 3 THEN move your cursor to the apply button (do not move the cursor from this position), press your source button till you get PC channel (which has no picture yet) then press your mouse button to apply, ( your picture will flicker on), and before the picture goes confirm with the yes button. You now have light! eureka :)
Posted on Jan 16, 2008
SOURCE: TV gets stuck on channel, won't advance past channel 7.1
Background:
I'm assuming you have Cablevision. This is becoming a known problem with their broadcasting system. They have been upgrading since last thursday and it has been causing the Sharp TVs to freeze up on channel 7.1. There have been reports of channel 21, 21.1, and 24 as well.
Simple way to fix it:
1. Unplug tv
2. Unplug coax from tv
3. Plug tv back in
4. In the Menu go to Setup > CH setup > CH Memory > Cable (digital)
5. Enable channel skip for channel 7.1
6. Push Menu to exit
7. Change to any other channel
8. Reconnect coax to tv.
Followup:
Avoid channel 7.1 and go give Cablevision a call and let them know about it. They won't do anything to fix it until they get a certain number of reported issues about the problem. Enjoy.
Posted on Mar 18, 2008
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
SOURCE: i need to know how to hard reset the samsung sch w420 or just give me the default phone code
i can fix your phone i can remove the lock code of your phone
Posted on May 16, 2009
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
Posted on Jun 05, 2009
Somehow I am getting "button locked" on every button but the power button. Does anyone know how to fix this??
A factory reset on several AOC models can be performed by unplugging the TV for 5 to 30 minutes. When it comes back on it should be reset to factory defaults and ask to do a channel scan. You have somehow enabled the so-called childproof or "Bar mode" of the TV which deactivates the panel buttons so kids (or patrons) cannot mess it up.
Sep 08, 2013 | AOC L24H898 24 in. LCD TV
Samsung LCD TV LE40R8 - Hard Reset
How do I reset the picture on my LCD TV to the factory settings?
The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
Nov 14, 2007 | Televison & Video
I accidentaly locked my panasonic tv when i try to check the channels its saying child lock..is der a way to override it thru the buttons on the tv panel instead?
If you can get into main menu you should be able too reset to factory defaults this should cure the problem. If not, try 0000 or 1234.these are the factory default codes one of them may work.. Hope this helps.
Apr 12, 2011 | Panasonic TCP50C2 50 in. TV
My Samsung LE37R8 TV always wants to go into
Unplug the tv about an hour,the tv should reset itself.U should able do,what u want to than.Still have the same problems,than the Tuner board itself,have problems.
Jul 09, 2010 | Samsung LE37R72B 37 in. HD-Ready LCD...
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Default code for samsung d880
Samsung D880 password. I am unable to reset the phone to factory default, it ask for password which I never given. Is there any default password or solution ? please tell me. Thanks
Nov 22, 2009 | Samsung D880 Cellular Phone
Need to reset phone
To reset the handset follow the steps below:
  1. While in standby mode, press the Menu / OK buttonmenu-ok.giffor Menu
  2. Select Settings (9)
  3. Select Phone Settings (5)
  4. Select Security (3)
  5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed
  6. Select Reset Phone (4)
  7. Press the left soft key for Yes to confirm resetting the handset to factory default settings
Note: All settings (except Contacts) are reset to factory default settings
Jul 19, 2009 | Samsung Hue (SCH-r500) Cellular Phone
I dont know how to delete all the contacts
You could reset everything back to factory settings if your starting from scratch. Go into settings and find 'master reset', as long as your sister hasn't changed the phones default lock code when prompted for phone code enter, '00000' or '00000000' one of these is default. Then phone will turn off and reboot and will be as fresh as the day it was first purchased.
CAUTION: if there is anything you dont want to erase DONT DO THIS as it will erase everything back to factory default!
Apr 23, 2009 | Cell Phones
Mar 23, 2009 | Samsung SPH-M500 Cellular Phone
How to disable parental lock
Go in and reset the code.
Jul 02, 2008 | Televison & Video
Televison & Video Logo
259 people viewed this question
Top Televison & Video Experts
Electro Med Services...
