Question about Ryobi Multi-Volt Battery Charger
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is RYOBI 18v charge plus.
  • Ryobi Master
  • 7,733 Answers
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Posted on Nov 08, 2010
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Makita bl1830 charges but stays on static red light
Chargers have been known to lie about what they are indicating. Even though you say the batteries were charged only a hanful of times, they may, in fact, have expired
Apr 03, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have an 18V cordless drill/driver. When I tried to recharged the battery, the battery stayed dead. The red light was on while recharging. The charger stand has red and green LED indicators but only the...
Chargers will out last batteries by a long time.You will need to get a new battery. Black & Decker is a cheap household brand and does not hold up for long periods of time. I have better brands and buy several new batteries every year.
May 30, 2011 | Black & Decker 18V Cordless Drill/Driver
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
Aug 26, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
When I put the 18V battery in the charger, the green and yellow lights come on and stay on, instead of the red. What's up?
i always thoiught that when you light is green it is fully charges yellow is weak and red is dead
maybe you have it reversed check it again also make sure that (altho hard to do) the battery is in right
Mar 08, 2010 | Ryobi 15" Electric Factory Reconditioned...
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
18v Litheon drill charger won't charge battery. Green light stays solid even though battery is dead.
It could be the battery or the charger. Best thing to do is find a Bosch service center and have them test them. The litheon stuff is fairly new, there is a good chance it will be on warranty.
Oct 17, 2009 | Bosch Drills
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi Multi-Volt Battery Charger Logo
550 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
