Samsung WF8500 NMW8 washing machine 5d error message. What is the solution? thanks
  • 17,970 Answers
The problem is most likely a defective pressure transducer on the main control. The pressure transducer sends the signal to the board saying the washer is drained. If the pressure transducer does not read zero out, it will give you the SD error code. I recommend unplugging the washer first. Then open the console and remove the hose from the main control. Wipe the end of the hose and blow into it. It should be clear. If the hose is clear, you will need to replace the main control.
Additional details and solution description could find in THIS LINK.
Hope helps (remember to rate this answer).
Posted on Aug 24, 2011
ERER CODE 5D?
Whirlpool Duet Sport ht 5D/F21 Error Fix - YouTube
? 5:40
https://www.youtube.com/watch?v=2dV3FLzWPTM
Aug 6, 2013 - Uploaded by Mariela Gonzalez-Aroche
Steps in this video may be used to repair both F21 and 5D error codes. ... which is located on the bottom right corner of thewasher machine.
Nov 01, 2015 | Washing Machines
My Samsung WF8602NHS stops and gives an error "5d" or "Sd"? Cant find the error code on the manual. Please help.
Other than ''bad computer board'', the only thing you can do yourself (besides replacing the board) is to unplug it from the wall for a _full_ 24 hours. Then try using it. Same problem = bad board.
May 18, 2015 | Samsung Washing Machines
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Cod error 5d samsung diamond?
http://skp.samsungcsportal.com/integrated/popup/HtgDetailGuide3.jsp?cdsite=uk&seq=2132&gubun=I&tabStatus=s&status=&step_no=1
Feb 26, 2013 | Samsung WF330ANW Front Load Washer with...
Long spin cycle of my Samsung WF8590NHM Front Load Washer is always interrupted and throws this flashing "5d" error code.
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
Aug 20, 2011 | Samsung WF306BHW High Efficiency Front...
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21, 5d, and now not working
I had to call the Whirlpool service man. He came and concluded that the control panel was the culprit. He said it could be that the contacts were bad, but he didn't want to unstack the washer/dryer (dryer is on top of washer) to check it. He was suppose to call me to day with a price for another control. I'm just going to go and buy another machine. Can you recommend a reliable front loading washer?
Thanks for all your help!!!
Judy
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error message 5d on kenmore he2 fron load
Hi mankin1,
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck. Mike Anderson mca0824@aol.com
Mar 28, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
518 people viewed this question
Top Washing Machines Experts
