Question about HP LaserJet 4mv Printer
The printer is printing really light. Just changed the toner.
  • HP Master
  • 7,733 Answers
My Dell 1720dn mono laser printer has not printed properly for some time - in fact it's dreadful! The letters and dark images have white vertical lines going through them, and some of the printing do
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Dec 05, 2014 | Dell 1720dn Laser Printer
We have a CLP-300 Series A laser printer which we really like. The problem we are having has recently surfaced after we changed the BLACK toner cartridge. There are skips and light area in the printing...
I think you should contact the manufacturer or vendor who sold you the cartridge. The standard warranty is 90 days. I believe that it will prove to be a bad toner/ drum (which are the same thing for this printer.)
Besides that you can do a "half-test". Stop the print job half way by opening a cover during the print process, before it is transfer to the paper and fused. Look at the drum or transfer belt and see whether the defect exists early in the print process.
There may also be a contact problem with the black toner. Check for bent metal on the toner, or chassis that should mate and conduct charge to the toner.
Whit
Item, Inc.
Dec 13, 2010 | Samsung CLP 300 Laser Printer
Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
b. Press the up or down arrow key to select OFF and then press OK.
c. Press Stop/Exit.
2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
Oct 26, 2010 | Brother MFC-9840CDW Laser Printer
Just change new toner but light printing problem
I hate to say this, but there's nothing you can do, these printers are notorious for printing blacks as grays. On the bright sde your toner will last forever.
Dec 24, 2009 | Samsung ML 2151N Laser Printer
My printer shows ayellow light - toner save-and prints faint
You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
I have changed the toner in my printer and the toner light continues to stay on/won't print. I tried changing the drum and still the toner light stays on/won't print. I tried opening the toner door and...
No guarantee this will work but I refilled toner on my Brother 5170 and it only worked after making sure the old stuff was completely out. After removing the little plastic plug, I tapped out the toner repeatedly on the side of a trash can (like 50 times) then took a shop vac and let that **** out whatever toner was left. It really seems to be important for some reason to rid the cartridge of ALL old toner before adding the new stuff. Hope this helps!
Feb 23, 2009 | Brother HL-2040 Laser Printer
On my Brother HL 2140 series printer, I changed the toner. I followed the directions that came with the toner, and it just won't work. When I put it in, the error light always comes on. I tried unlplugging...
Open the front cover
Turn off the printer
Keep the go button pressed and switch on the printer
Once all light is lit release the go button
Press the go button twice again
Press the go button six times again
Close the front cover.
This should solve the problem
Nov 12, 2008 | Office Equipment & Supplies
Drum light on Ready light on Alarm light on Data light on
Alarm and Data lights on together is from low toner. If shaking of the toner cartridge is not helping, change the toner.
Drum light is usually on because of the print counter. If the print quality goes really bad, change the drum and reset the counter by holding the front button wile the front cover is open till all lights come on. Release the button and close the cover.
If just Data light is on, check the print ques, some jobs might got stuck there.
Apr 28, 2008 | Brother Office Equipment & Supplies
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Apr 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
HP LaserJet 4mv Printer Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
