Question about HP Compaq d530 SFF PC Desktop
Motherboard led lamp is flashing. computer does not start-up.
    Problem Solver:
  • 4 Answers
Just a thought,if you did not hear the usual beep or a different sound your problem may be memory related.sometimes removing it and re seating it helps or if you have more than one you can see if it's one that went bad.but before you go to do that.check the monitor cable to make sure it's plugged in and the power cables to the monitor.hope this helps :)
Posted on Nov 08, 2010
Why does my dell mp1800 power and lamp flash orange
the battery needs charging. it is charging when it is solid orange and green when it is fully charged
Aug 22, 2014 | Dell 3.8 GHz Second Processor for...
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Flashing lamp light
You need to buy a new lamp.....easy to install, but the lamp will be about $200
Nov 27, 2007 | Sony KDF-E55A20 55 in. LCD Television
Problem with the lamp
According to Epson the led will flash red in one of two cases: Flashes red with 1 sec intervals - either the lump has burned out(We can rule this one in this case) or the lamps cover is open (try checking the cover's sensor) Flashes red with 2 sec intervals - an internal problem, I'd suggest contacting Epson's support. Good Luck
Jan 11, 2006 | Epson (V13H010L13) Projector Lamp for...
HP Compaq d530 SFF PC Desktop Logo
413 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
