Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
How do I stow Lexmark Impact S305 Control Panel? The printer control panel is stuck in the up position.
  • Anonymous Mar 27, 2014
    printer home options do not respond
    scan options do not respond
    New Friend:
Find a tight plastic locking clip on the underside of the control panel. It may be at the top middle edge on the underside. Give it a very firm upwards press and it should unlock the control panel section.
Posted on Nov 13, 2010
SOURCE:
How do i clean the print head on my lemarkS300-S400 Series printer?
-From the printer control panel navigate as follows:
Spanner>Maintenance>OK
-Locate the option "Clean Printhead" or "Deep Clean Printhead" and press OK
-Press OK again
A clean will now be performed and a test page printed.
Hope this helps.
Nov 29, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
How do i get the pairing code for my lexmark s305
1 Insert a Bluetooth USB adapter into the USB port.
Bluetooth Dongle Connected appears on the display.
Note: A Bluetooth adapter is not included with the printer.
2 From the printer control panel, press Setup.
3 Press the up or down arrow button to scroll to Bluetooth Setup, and then press OK.
4 Press the up or down arrow button to scroll to Security Level, and then press OK.
5 Press the up or down arrow button to select the security level, and then press OK.
• Select Low to allow Bluetooth devices to connect and send print jobs to your printer without requiring users to enter a pass key.
• Select High to require users to enter a four-digit numeric pass key on the Bluetooth device before connecting and sending print jobs to the printer.
6 The Bluetooth Pass Key menu opens on the operator panel display if you set the security level to High. Use the keypad to enter your four-digit pass key, and then press OK.
Jun 12, 2012 | Lexmark Impact S305 Wireless All-in-One...
Colours not printing only black is
Make sure that you're using genuine Lexmark cartridges. If you are, try the steps below:
- Update the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
- Perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If you still have the same problem after performing those steps, it could be a problem with the printhead. You might want to contact Lexmark's technical support.
May 18, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Lexmark S305 IMPACT Prints incorrect colors
Try to perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
Apr 21, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Installed new printhead on Lexmark s305 and now my adobe photoshop elements 10 program can not scan but prints fine.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/guXLhl. Select your operating system, download and execute the file.
Mar 08, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
When I go to print a document, it pulls the paper through, but does not print
Try to clean the printhead nozzles on your Lexmark Impact S305 printer. From the printer operator panel, press Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a page forcing ink through the printhead nozzles and clean them.
If that doesn't help, please visit the Lexmark support page to determine if your printer is affected with the printhead issue. Also, make sure your printer is updated. The firmware update will help give you a highly reliable print system.
Click here to validate your serial number and/or update your firmware.
Sep 01, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Hello, I allways get papperjam in my lexmark Impact S305 printer... How do I solve the problem?
Check Lexmark article on Paper Jam Troubleshooting on 2009 Printers. If you continue to experience paper jam issues on your printer, please contact Lexmark Technical Support Center for additional assistance.
Jun 22, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Impact s305 printer won't scan. it's stuck on "downloading application list"
Try using the Lexmark Printer Home when scanning. If you have a PC, to access it click on Start > All Programs > Lexmark > Printer Home. You can scan to a .jpeg, PDF or .doc.
If you're scanning from the control panel of your printer and you're getting an error message, "Cannot Retrieve Application List", most probably your firewall is blocking your printer from downloading the applications. You might want to add the Lexmark files in the exception of your firewall. Click on the link on how to add exceptions to your firewall.
If you're trying to scan to email (email client), try to check this link: http://bit.ly/k0w0Hp
Mar 11, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Lexmark Impact S305 control panel problem
We had same problem and this helped us. But you have to move your finger just to the right of the ridges and press firmly- you'll hear it click as it releases
Mar 25, 2010 | Office Equipment & Supplies
I have just bought a Lexmark S305 Impact printer/scanner/ copier. Having raised the control panel on the front, how do you stow it away?
Try as I could (Using a mirror and flashlight and feeling all around), I couldn't find a 'Lever' anywhere, but what I finally did find was that there are three thin molded plastic lines right there up under the center back of control panel. While holding the top of the printer (above the panel), and using one finger, I pushed up hard on those plastic lines. After a moment of pushing on them, I heard a 'click', and that released the panel so now it moves up & down again. It can be adjusted at whatever angle I like just like before it locked. If I want it to remain up, I just lift the panel all the way up until I hear that 'click' again. Hope this helps.
Nov 29, 2009 | Cars & Trucks
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
939 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
