Question about Lite On SOHR - 5239V (SOHR5239VBULKB) CD-RW Burner
Won't open - Lite On SOHR - 5239V (SOHR5239VBULKB) CD-RW Burner
    Master:
  • 362 Answers
Hello, look for a small hole somewhere near the centre of the cd drive drawer. Straighten out 2" of a paperclip, and insert the straightened end into the hole until you meet resistance.Push firmly and the drawer should begin to open.The more you push the paperclip in, the more the drawer will open.
Regards,
nicam49
Posted on Nov 08, 2010
Trunk won,t open so I can get to boot to open mu gas tank
Have you checked the fuse panel for blown fuses? If not, check there first. If so, check to be sure all the wiring harnesses in and around the fuse panel are tight ans secure. If you're really in a pinch and you have rear folding seats you can crawl into the trunk that way.
Jul 24, 2013 | 2003 Audi TT
The trunk on my 2008 toyota corolla won't open
I just had the same problem this morning. The light indicator for 'door open' is on and now my corolla won't start. Were you able to start your car?
Feb 01, 2013 | 2008 Toyota Corolla
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Fuel door won't open
Fixed. In the glove box there is a vallet button. I pushed it and now my trunk and fuel door work. and what this has to do with my trunk and fuel door not functioning , I have no idea. Hope this helps someone else.
Apr 05, 2012 | 1998 Cadillac DeVille
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Bill DeLisi
Bill DeLisi
paul shaw
Level 1 Expert
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
