Question about GE Profile PDW8000G Built-in Dishwasher
Ge dishwasher will not stay on unless push on door panel at the top?
SOURCE: GE Max dishwasher no lights on panel
I reset the breaker and still doesn't work. Any suggestions?
Posted on Jun 22, 2008
  • 52 Answers
SOURCE: front door panel, stainless for GE dishwasher
For your particular model, the panel is only available in white, black and almond. However, they do make an adhesive paper that looks like stainless steel and might work for you. I found one link where they carry it, but you could research it further online if you think this solution might work for you. Click here to see what it looks like.
Posted on Jun 25, 2008
SOURCE: dishwasher will not drain at end of cycle unless
did that already
Posted on Aug 12, 2009
  • 246 Answers
SOURCE: Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Posted on Feb 25, 2010
  • 89 Answers
SOURCE: GE Nautilus dishwasher won't continue through
Hi, In reading about your dw problem, you are in need of a complete door switch assembly. You will need the full model number, and then find your nearest ge supply house to purchase the part. Hope this helps.
Posted on Jan 20, 2011
My kitchenaid DW kudc101xwho will not stay on. Runs a few min and shuts off. Is this the control panel or the timer?
May be this is the reasons.
a) May be your door latch is opening due to pressure inside the dishwasher. The door latch opens and the dishwasher will stop. Quite common problem on KITCHENAID. KitchenAid door is a heavier door compared to sister product WHIRLPOOL. If door latch problem then has to change the door lock along with the top latch.
Sep 25, 2014 | KitchenAid Dishwashers
My Dishwasher won't start unless I push firmly on the door.
Change the handle there is a switch on the handle that activates when the door is closed the switch is broken you have to buy the whole handle not just the switch
Apr 11, 2013 | GE Dishwashers
My dishwasher door will not stay up unless locked. I have installed new springs, to no avail
Might help with solution if you provide make and model number of dishwasher.
Sometimes the solution is a simple as ensuring the dishwasher is level so that the door shuts. The spring tension may need adjustment and usually there are a few screws at the top of dishwasher panel. Depends on make and model.
Jan 05, 2013 | Dishwashers
Dishwasher will not start unless I push the door in further
could you please let us know the model #
thanks
sb on the door frame if not go here for a model# finder
http://www.neff-home.com/uk/service/manual
Jan 22, 2018 | Neff Dishwashers
My GE 24 in. GSD980X dishwasher detergent dispense door will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 24, 2011 | GE 24 in. GSD980X Built-in Dishwasher
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
START/RESET LIGHT STAYS CONTINUOUSLY ON
This is normal. The door latch has safety switch that will not let the machine do ANYTHING unless door is latched. If you need to do maintenance, then you can pry with a screwdriver, or possibly tape the switch so the machine can still run
Mar 01, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwasher leaking
There is a front door seal that may be the issue. It seals along the door sides/top and continues under the door to seal the bottom surface when closed. Mine pulled out of the seal channel under the open door where you can't see it without a small mirror. The seal took a "fixed set" out of the channel so now it will not stay put. It requires replacement.
Hope this helps.
Jan 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Battery put accidentally inside the front frame of the dishwasher
Nothing Unless The Battery Is Visible It Should Not Get Wet And Just Remains Inside The Door And Wont Affect Operation.
Jan 05, 2009 | Dishwashers
GE Profile PDW8000G Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
