Question about LG LFX25950 Stainless Steel (247 cu ft) Side by Side Bottom Freezer French Door Refrigerator
L.G. refrig. model lfx2595osb and gets no water to icemaker, the water valve only has one seloniod and only one water line going to upper right of refrig. . water dispenser works, is thier another water valve on this refrig.
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
lojacksdad
  • 121 Answers
SOURCE: new water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Posted on Apr 13, 2009
SOURCE: GE REFRIG MODEL GSL25KGRB BS
I have had the same issue several times, the water line in the door is frozen.The Soulution:  I left the door open for several hours and put a peice of Sheetrock over the opening to keep the cold air in. Worked like a charm, the water started flowing for a couple of months then it happened again.
Posted on May 01, 2009
  • 72 Answers
SOURCE: Icemaker works; water dispenser not
You can get to it, it is just a matter of figuring which valve has gone bad. You may need to disconnect different lines and actuate the water dispenser to see if water comes out of the valve. You gain access to the valves from behind the machine by removing the access panel that is at the bottom
Posted on Jun 16, 2009
  • 245 Answers
SOURCE: no ice & water in water dispenser on Whirlpool side-by-side refri
take the hoses off the other side of the solenoid and have someone push the button to check the valves usually they are the problem unless you have very hard water in which case you can use compressed air to clean them while they are off the valve.
Posted on Jun 26, 2009
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
The ice maker is not working anymore and the light inside the freezer is flashing red.
Do you have water at the dispenser?
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
Ice maker not working on model #frs24zsg
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Kenmore model 79578502800 refrigerator error code 1F. icemaker does not work
Jun 05, 2010 | Refrigerators
Ice maker is not working
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a G E. modle GSS22UFMD WW .SIDE BY SIDE. I,M NOT GETTING WATER TO DOOR,ICE MAKER. I PUT NEW FILTER IN THAT DID NOT HELP. I UNHOOKED WITERLINE UNDER FRONT DOORS NO WATER IN LINE,WHEN I TAKE WATER...
Did the icemaker and water dispensor quit at the same time ? Your model has the 2 lines coming from the top ( filter ) behind the refrig . One line to the wall water line to filter and the other coming down to the water valve . Do you have the filter bypass piece that came with the refrig ? Use it to test . Remove the back panel . If both stopped at the same time , check the connector that the wires connect to . With 2 connectors on each solenoid , those 3 or 4 wires go to a seperate plug in . Check this plug in . If wireing seems ok , remove the larger tubing from the valve by pushing in on the white ring and pulling the tubing out at the same time . Press the water dispensor , and see if water comes out of the valve . If it does , (you said you disconnected the tubing below the freezer door and no water came out while activating the water dispensor ) then the tank at rhe bottom of the refrig section behind the crispers , is frozen . To thaw , use a hair dryer with the light bulbs in the refrig section , unscrewed slightly . This is only for the water dispensor . For the icemaker , disconnect the smaller tubing , while someone else , turns the icemaker on and off several times to see if the valve momentarily opens each time the icemaker is turned on and off . I think the water valve wiring plug , has something to do with this because I have never found a G E where both quit at the same time without it being that plug ( 2 times ).
Aug 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model #ed5lvaxvqoo; ice maker quite working, no water WHIRLPOOL
Due to your refrig having the ice bin on the door , it could be a little bit more difficult to diagnose . Pour about 1/2 cup of water into the icemaker . If it doesn't dump , then the problem is the icemaker . When you open the freezer door , does the laser lite flash 2 times then pause then 2 times etc.? If the lite does not flash , it means the icemaker is in the harvest mode (dumping) . If stuck in the harvest mode , replace the icemaker . If the icemaker dumps the frozen cubes , then the black fill tube above the fill cup , could be frozen , or the water inlet valve is bad . If you feel ice in the black tube ,(water valve bad due to slow drop leak ) you'll need to pull the fridge from the wall , and see if there is a plastic coupling on the tube going up to the icemaker . If not , you should get one in case of future problems . Cut the tube (or disconnect the fitting ) (if you can blow thru it , black tube is not stopped up with ice ) and turn the icemaker off . Turn the freezer setting down a number or two . Go by ocassionally to see if you can blow thru the line . This water line goes between the top of refrig and the inner liner . Bad design because if it freezes , no way to get to it . Can try hair dryer2.gif on top of refrig . I have known it to take several days for this line to thaw .
Aug 28, 2009 | Whirlpool Refrigerators
LG LFX25950 Stainless Steel (247 cu ft) Side by Side Bottom Freezer French Door Refrigerator Logo
55 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
