Question about Linksys Wireless-G WRT54G Router
When my pc starts I get an error message concerning something missing in the dynamic link library. How do i fix this?
  • Linksys Master
  • 7,733 Answers
Try:
Resetting the Linksys Router to Factory Default
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRTwhen my pc starts I get an error message - 4030-024.png
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administrawhen my pc starts I get an error message - kb4008-004_en.pngck on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here. Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Posted on Nov 08, 2010
What is dll file
dll stands for dynamic link library, Its a windows procedural program for multiple code sharing for use between resources
May 11, 2015 | Computers & Internet
How do i solve an error about the ordinal 231 missing in the dynamic link library ietutil.dll.
I would run a registry cleaning programme. There are lots of free ones out there that work.
Nov 05, 2014 | Computers & Internet
How do i reload ordinal 459 into dynamic link library urlmon.dll
This error comes up when something is wrong with Internet explorer.
Thankfully some has listed the solution as it is quite complex.
Fixing error message The ordinal 459 could not be located in the dynamic...
Oct 05, 2014 | Computers & Internet
How do I fix a missing Wlanapi.dll
well u can manually download the dll or do a repair on ur current OS with the OS disc that should definitely do the work or try to update the drivers of ur wifi.
. DLL files com helps you with 1000s of dll files ready to download for...
wlanapi dll free download
Apr 30, 2014 | Computers & Internet
The ordinal 120 could not be located in the dynamic link library iertutil.dll
iertutil.dll is a dynamic link library used by Internet Explorer. Ordinal 120 refers to something inside the dynamic link library. These errors typically occur when the file is corrupt or there is a version mismatch (eg. IE 9 using iertutil.dll from IE 8). A reinstall of IE should fix this problem
Ericthecmh
Oct 05, 2011 | Microsoft Windows XP Professional for PC
Cannot open program , get the following message: Procedure entry point cannot be found V@YAXPAX@Z in dynamic link library msvcrt.dll.
The message you are getting indicates the the copy of msvcrt.dll is not compatable with the program you are running.
By the way msvcrt.dll stands for Microsoft Visual C Runtime Library and is a 'dynamic link library' in case you were wondering.
I would recommend one of the following:
1: Contact the programs publisher and ask them about this issue and what version of this library IS compatible with your program.
2: Find the version of the copy of msvcrt.dll you have by going to C:\windows\system32\
find msvcrt.dll, right click on it and click on the 'Version' tab and write down the version number.
Go online and acquire a newer version of msvcrt.dll and place it in C:\windows\system32\
Jun 20, 2011 | Computers & Internet
Error messege on startup
you might need to reinstall windows because of a registry error
May 29, 2009 | Microsoft Windows XP Home Edition
Error Message at Windows XP start up
Im assuming you have BT Broadband? If you delete BT Helper or something along those lines from Start -> All Programs -> Startup that should fix your problem.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Linksys Wireless-G WRT54G Router Logo
250 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
