Question about Stanley Bostitch MIIIFN Flooring Nailers
I have rebuilt an mIII flornailer and it is still hissing air out of the top
  • 154 Answers
If you have replaced all the o-rings and the unit is still leaking air, there a couple of things possibly wrong. One, there may be an o-ring that came out of its groove and is leaking, or possibly the main stem of the piston assembly is worn down to the point where the o-rings can't seal anymore (even new ones)The stem will need to be replaced. Either way you are going to have to open the unit up again and see whats up.
Posted on Jan 13, 2011
  • joshzazula
    joshzazula May 02, 2012
    You said the main stem could be worn down so the o rings don't seal, but the main stem doesn't have any o rings on it. How would the stem be the problem? I have an miii and I replaced the o ring kit twice and it still leaks. My friend told me the same thing you said and bought me a new stem, but I do not understand how this part can be the issue. Can oyou please explain?
Hissing noise
air leak check the air lines... look for cracked and split lines spray some carb cleaner around and it will change the engine speed were the leak is.
Feb 22, 2014 | Ford Cars & Trucks
Under acceleration there is a loud hissing/suction sound as if there is no air filter on the motor.
If the hissing is coming from under the hood,you have a vacuum leak at one of the hoses,EGR valve on top of the engine, or a hose off someplace like the line going down to the transmission. An easy method to check where, is toget a can of spray starting fluid, and spray a tiny bit in a few places around the engine. When you hear the engine rev up,your very close. If the hissing is inside the cabin, check the hoses at the climate control or the blend air door motors.
Jul 19, 2011 | Jeep Cherokee Cars & Trucks
Leaking sound coming from top
hi buddy the pipe that comes from the pump to the tank connects to a non return valve (pic below) on the tank unscrew the end of this and turn the rubber around inside and try this get back to me if no difference 9d71ea5.jpg
Sep 20, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
System will not hold coolant, there is a hissing sound coming from the lower belt driven unit, I think is is the clutch assembly. When I push in on the pulley and clutch assembly the hissing almost stops...
That unit you speak of is the compressor and compressor clutch if its leaking at a fitting on the compressor its not to expensive to fix but its comming from behind the clutch assy that it is the compressor shaft seal and may mean a new compressor. you can find rebuilt compressors for a couple hundred bucks. but the system will have to be serviced by a certified a/c tech because the system will need to be evacuated down to 29inches of vacume before any refrigerant can be added so to see if there is any other leaks and rid the system of all air and moisture.
Jul 21, 2009 | Heating & Cooling
Gp sharper image hissing problem
1. Unplug the unit
2. Turn the unit upside down and listen for the beeds to move along the static wires from top to bottom. Turn it upside down again and again until you feel the static wires are cleaned of grime.
3. Plug it in again and see if the hissing is gone.
Jun 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Stanley Bostitch MIIIFN Flooring Nailers Logo
197 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
