Question about Briggs & Stratton 2200 PSI Gas Pressure Washer
My pressure washer a briggs and stratton 550 won't start
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
First off make sure the oil is full in the crank case.
Remove the spark plug and check for spark with the Engine on / off switch ON.
If there is good spark then turn off the fuel and remove the float bowl by unscrewing the bowl nut.
1) Remove all of the debris from the float bowl. It must be very clean.
2) Clean the bowl nut. This to must be very clean.
3) In the threaded area that the bowl nut screws into there is a Brass fuel jet. You must make sure that the pin hole of the jet is free of obstructions. I use a round toothpick broken in half. Use it like a scraper and clear the pin hole of the orifice. DO NOT force the toothpick into the orifice hole. It will break off and clog the orifice. Spray carb cleaner downward into the brass tube in the carb throat making sure that the carb cleaner passes through the jet orifice.
4) Use a spray paint can lid to catch fuel and turn on the fuel. Fuel should flow enough to fill the spray paint can lid in 8 to 10 seconds with the float hanging down. Raise the float gently to the level position and make sure fuel flow stops. (If you are not getting fuel to the carb remove the main fuel line at the carb and check fuel flow.) I.e fuel selector lever on and off. Poor fuel flow here = clogged fuel tank outlet port of debris in the fuel shut off valve area.
5) Install spark plug fuel lines and float bowl.
6) Attempt start. It should start. If it does not start squirt a small amount of fuel into the carb and try a start. Just respond here with symptoms. I.e have fuel.. have spark / fuel in carb throat = brief start or no start.
There is more that can be done.
Thanks for choosing FixYa,
Kelly
Posted on Nov 08, 2010
2 Suggested Answers
Tnsiouxfalls
  • 617 Answers
SOURCE: Briggs and Stratton pressure washer fuel leak
You've hit the nail on the head.The float,needle and seat are stuck wide open.Once the carburetor bowl is full of fuel the float rises up on top which pushes the needle back into the seat shutting of the flow of fuel.As the engine consumes that fuel the float drops and opens the needle and seat filling the bowl and shutting off the fuel again.Things that cause this process to not work are:forgetting to empty or run out the fuel before storing it for the winter.Sediment buildup in the bowl.Mineral deposits in the needle and seat.
Not emptying out the carb can leave water in the bowl which freezes,crushing the float.It also promotes sediment buildup and mineral deposits.The float when crushed or cracked will not float,nor shut off fuel.Sediment takes away capacity of fuel in the bowl,very necessary for wide open throttle.Mineral deposits build up to the point that the needle and seat can't make a good seal so fuel will continue into the carburetor.
Enough information yet?
To repair,take the nut off the bottom of the carburetor bowl.There are the float and needle and seat assemblies.All three need to be replaced,$10 max.After you get the parts replace one piece at a time so you can see how they go together.Next replace the spark plug, engine oil and air cleaner.They are fuel fouled and even if you could get the engine started will only add more damage to your engine.BEFORE you put the new plug in cycle the engine by pulling the starting cord a few times to get rid of the excess fuel.When there's now more fuel in the cylinder replace the plug,filter and oil.
That's it!Take your time and you can do it just fine.Re-post if you have any more troubles.
Posted on Jan 13, 2010
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
Craftsman 2400psi 6.0hp briggs & stratton pressure washer won't start
try and start it with starting fluid if so rebuild the carb
Aug 07, 2012 | Garden
Pressure washer won't deliver pressurized water.
sounds like you have a blockage maybe in your water hose ,ideally your water hose should be around 25 feet..or you may have an o ring in the gun where the tip goes.. is broken..that will affect your pressure..check also filter where water hose connects to the pump make sure thats clear
Sep 30, 2017 | Briggs & Stratton Briggs Stratton 1800...
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Briggs & Stratton 2200 PSI Gas Pressure Washer Logo
5,044 people viewed this question
Top Briggs & Stratton Garden Experts
John Trevino
wadingriver
wadingriver
Jim Parker
Jim Parker
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
