Question about Bose Cinemate Digital Home Theater System Speaker
I just got a new samsung tv and the audio out is different from my old one. i used to be able to connect my cinemates red and white cables to the red and white jacks for the audio out. however, my new tv has an audio out but there is only one jack and its black, not red and white!
  • 23 Answers
That's probably a digital out. I'm really surprised it doesn't left/right standard output in addition. Are you using a separate AV receiver? If so, and it's a new model, it should have a digital audio input, and then you could send your signal out to your speaker system.
The digital audio connection uses a unique type of connector and a special cable.
If your TV has a red/white pair out from another source, you should be able to select on a menu which audio output to utilize.
Posted on Nov 08, 2010
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
When I hookup my Bose Cinemate System to my new Samsung tv. I am hearing feedback along with the sound. I called Samsung support line and they said it would not be the tv. I haven't talked to Bose yet. I...
You're not supposed to have the TV sound and the Bose osund on at the same time. Due to differences in digital audio processing there will be delays that sound like echo, not feedback.
If you truly have feedback, define the audio connections and exact cabling to/from all components..
Mar 13, 2011 | Bose Cinemate Digital Home Theater System...
I have a Bose Cinemate System and a new LG Plasma TV that it will not work with. The Bose system connects using red and white RCA connectors and needs it to be plugged into an Audio Out. The only Audio Out...
If you're using a Cinemate for HDTV listening you're missing out on multichannel sound. However, since it only supports analog 2-channel audio AND a TV or monitor is NOT a meaningful contributor to the listening experience, maybe you could extract the TV audio from the cable box where it ultimately originates in the first place. I'm sure it has a convenient and compatible RCA pair.
Dec 28, 2010 | Bose Cinemate Digital Home Theater System...
How to connect a bose cinemate to a panasonic tv digital audio out cable is not red and white what do i need
Get the best audio for whatever the TV is viewing from the same source (cable/dvd/blu-ray/sat). They will all have at least analog RCA audio output. The TV is not a primary source of audio in these cases.
The cinemate is not really intended for complex installations.
Dec 26, 2010 | Bose Cinemate Digital Home Theater System...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
How do i hook my bose cinemate system to my lg tv?
If you lg has Optical Output, Which is a 20.00 Toslink Cable, You hook the cord into the Tv using the Optical Output Port then run to the optical in or DIGITAL In on the Cinemate, If you don't have the option to run optical Check for Red and White Monitor Out from the TV and Run into Red and White on the Cinemate.
Dec 15, 2009 | Bose Cinemate Digital Home Theater System...
Bose cinemate no sound
Yes it will work coming straight off the dirctv box. What kind of tv do u have that doesnt have an audio out. I have had to actually use rca splitters to get sound from bluray and cable box because the new samsung led tvs only have optical out. Dont forget the unit not being used must be off or u will have 2 source sounds at one time playing.
Jul 03, 2009 | Bose Cinemate Digital Home Theater System...
Surround sound
your tv might have aux out on the back, I would use that first.
IF NOT, then you will need to use the cable box.  Insert the red and white plugs at the other end of  this cable into the AUDIO IN TV or cable box connectors on the
media center.
Be sure to match red to red and white to white.
3. Use your TV remote control to turn the TV speakers
down to minimum volume.
This prevents the echo effect of audio playing
through both the TV speakers and your 3•2•1®
system speakers.
Apr 09, 2009 | Bose Cinemate Digital Home Theater System...
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Connecting my HDTV to my Bose Cinemate
If your BOSE system only has one audio input you will have to connect everything to your tv and like the other guy said there will be an audio out on the back of your tv, connect that to your BOSE and when you switch inputs on your tv it should send that audio to your speaker setup.
Sep 02, 2007 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
329 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
