Question about Polycom >>> SOUNDSTATION PREMIER EX /AVAYA CO-BRANDED (230501900001)
I have a Polycom Soundstation EX, Model P/N 2301-03323-001P. It was suppose to be compatible to the Avaya Destiny phone system. Can you tell me if it is this model an analog or digital unit?
Can anyone tell me how to place a conference call using the Polycom SoundStation2 when both calls are incoming? I am able to place an incoming call on hold and dial another number and conference them...
No it can't. One call at least must be dialed out to. Try using a conference bridge service if you want to have multiple parties call in to you. Then you and all guests only need to call bridge number which is usually toll free.
Feb 21, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
I need to get the connector color code for a Polycom Soundstation conference phone.
From bottom of connector (not clip side)
Black
Brown
Red
Orange
Yellow
Green
Blue
White
Feb 08, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
I need the color code of the conference phone from the adapter to the phone
Does anyone have the color code to the Polycom Soundstation connector? The end fell off and I want to crimp on another.
Thank you.
Jan 28, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
What is the station type to use when hooking this polycom sound station premier EX to an Avaya S8300 on a digital port card?
The Polycon Sound Station Premier coference phone is an analog device. You need to connect it to an analog port on your phone system.
Dec 13, 2010 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Need a user Manual
here the most i can find
The SoundStation Premier and Soundstation Premier EX has been discontinued and is no longer available for purchase. Support for the product will be available until 02/21/2010.
http://www.polycom.com/global/documents/support/setup_maintenance/products/voice/soundstation_premier_user_guide.pdf
Mar 19, 2009 | Lands Phones
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
Oct 22, 2007 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Polycom >>> SOUNDSTATION PREMIER EX /AVAYA CO-BRANDED (230501900001) Logo
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
TEKUSER
TEKUSER
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
