Question about Dell Studio 15 Laptop
DVD is stuck and drive is not listed - Dell Studio 15 Laptop
    Problem Solver:
  • 17 Answers
Please try to turn off the computer.
Give it 30 seconds to let the Hard Drive's disks stop spinning and then turn it on.
While the computer is at the early booting stages please press the DVD's eject button to get the media out.
Please check the media for defects as this could be the reason for the situation.
Posted on Nov 08, 2010
    Guru:
  • Dell Master
  • 1,705 Answers
Look very closely at your dvd drive bezel, you should be able to see a small hole usually just below the draw.
Straighten out a paper clip and push it, quite firmly into the hole, this is the failsafe method of opening a locked/jammed disk drive.
Open stuck cd drive
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Oct 27, 2013 | Computers & Internet
The laptop has an usb connection dvd-rom. I started an installation of windows XP, by the time i got to the screen where i choose the , i found out that there is not enough space on the HD. Now i want to...
Connect the DVD drive.
Try getting in to the BIOS by tapping F2 when the computer powers on.
Go to BOOT and change the first boot device to the DVD drive. Make sure that the name of the DVD drive is listed there.
Save it using F10 and it will try to boot from the DVD drive.
Dec 24, 2010 | Acer TravelMate 340T Notebook
It is stuck. I have tried putting a straightened paper clip. does not work. no light, no response. stuck, stuck, stuck
Shutdown the PC and try to insert straithtened paper clip in the small hole provided in front of the CD/DVD ROM drive.
Dec 04, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Replaced IDE DVD writer with a SATA DVD writer. Powered up XP Pro system, but no drive letter shows up. There is power to the DVD drive, but the OS does not see it. No BIOS updates available from EPoX.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Cheers!
Mike
Oct 22, 2009 | EPoX EP-4PDA3I-3 Motherboard
Disk storage medium stuck in DVD-Rom.
If there is a disc stuck in the drive, removing the drive from the case is not necessary. Just take a paperclip and stick it in the manual release hole in the front of the drive.
Jun 22, 2009 | Dell CD-ROM DRIVE 8X 7G828 DVD Drive
How do I install a SATA DVD drive in my 655A V1.0?
Hi stewwiles, If your bios does not see & list the drive neither will windows hardware manager/ device manager. Check your manual. Enter your bios. The DVD drive should be listed in the same menu as your hard disk drive. Than go to the title "Boot" in your bios & make sure your DVD is listed in the boot order. (List of normal boot order):
1st boot device= Floppy drive
2nd boot device= DVD drive (model no#)
3rd boot device= Primary hard disk drive (model no#)
Make sure your DVD's jumper setting is set to "Master".
Mike
Nov 13, 2008 | Foxconn Computers & Internet
Drive wont open/eject
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Apr 17, 2007 | LG GSA 4163B DVD±RW Dual Layer Burner
No DVD-ROM boot
If you have put a Windows system disc in your dvd drive, then re boot your pc should find your cd then say press enter, but if it's stopping before you get there, an error has occured. Did you hear 2 beeps(not together) Go back into the bios and go into the 'standard cmos settings' and at the bottom you will see a line saying 'halt on all errors'. Also check that your HD drives are listed as they should be; and not an old drive, if you have changed your drive that is. Dissable this and save settings and try booting again to your dvd drive.
Oct 25, 2006 | FIC P4M-915PD2 Motherboard
Dell Studio 15 Laptop Logo
52 people viewed this question
Alun Cox
