Question about Gateway (M520HD80G) Hard Drive
How do i find what hard drive i need for gateway computer it dont have one in it
  • Burim Hoxha Nov 08, 2010
    What model of Gateway is that
  • deanhomes Nov 08, 2010
    atxstf fed gp7-800
    Guru:
  • 1,705 Answers
Check the make and model of the motherboard, then log onto the motherboard manufacturers web site and download the relevant user guide. This should give you all the details you need.
A couple of hints, if its a laptop you'll need a 2.5 inch drive.
If its a desktop, a 3.5 inch drive.
Check the mother board for IDE or SATA interfaces,
If its got just the old fashioned IDE (PATA) interface that governs the type of drive you can use
if its got both, go for SATA they're bigger, Cheaper and quicker.
If you're going to use windows XP, the older PATA makes life easier.
Posted on Nov 08, 2010
Where is the hard drive on a gateway all in one computer. i opened it up and dont recognize which part it is.
Hello.
Which model Gateway all in one do you have?
I have a Gateway ZX4800 and the hard drive is under the center rear cover. You have to remove the smaller panel that sticks out near the base of the PC (where the RAM is located) first then the center panel that is taller will pull out and reveals the hard drive cage. unbolt the hard drive cage, remove the SATA and power cables and you can then replace the hard drive.
On other All In One PC's (like the HP TouchSmart series) there is a rear cover that is under the desktop stand that can be removed and the hard drive is in a metal rectangle cage on the left side.
So, in almost all AIO systems, the hard drive is accessible by removing one or two panels off the back of the unit. RAM for these units will also be visible too.
Nov 02, 2013 | Computers & Internet
How can i reset my gateway gt 5228 to factory settings?
Hi blainholdens,
You cannot delete everything on your hard drive if it is your main operating system drive. If you don't have a CD with which to install your operating system you will have to install the hard drive into another PC as a secondary drive, open 'My computer', right click on your hard drive and select the 'format' option from the drop-down menu.
Formatting the hard drive is effectively erasing all data from the disk and making it active and preparing it for starting new.
Best wishes,
Graemevm
Jan 12, 2012 | Gateway GT5228 (7156) PC Desktop
I turn on the Gateway and the words Gateway come on screen, then it goes black. The keyboard is on then off then comes on again, Screen remains black.
You have a problem with the operating system. It has crashed. You will need to reinstall the operating system in your computer. Before you do that you need to back up your file in your hard drive.To do that you need a 2nd computer get a hard-drive closure external take out the hard drive of your gateway. and plug it in to the external closure and plug it in the computer and explorer and move the files you need to the other computer. After that put the hard drive back into the gate
Your computer came with a recovery disc. Use that to reinstall your computer and software. That will help your problem. Update your computer to make sure it doesn't fail again.
Mar 09, 2011 | Gateway 504GR PC Desktop
Nv79 gateway shuts off after it trys to boot?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | Gateway Computers & Internet
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Howvto replace hard T-1616
1ºst is the Hard Drive making funny noise?, like Scrathing? Has the Bios dont Detect? It´s very hot in Hard Disk? If not. you have a serious Virus Problem, instaled in the Bios Hard Disk. Just Low Level Disk format, and use the Hard Disk Utils for HardDisk Company. 90% of Hard Disk Problems is Virus Problems
Nov 21, 2009 | Gateway Computers & Internet
Our 2002 Gateway computer will not recognize a USB
Go to the following website listed below and download the file you need. It needs to be placed in the C:Windowsinf directory (not in any folder).
http://www.infdump.com/download-inf-file
Nov 15, 2009 | Western Digital WD Passport 250GB Portable...
Operating system not found problem
Easiest way to check is to change the cable and run your computer again! If you have same problem occures it does not mean that your hard drive is wrong.Just intert the boot CD and try to repair it if that fails or crashes or simply restart your computer then you have problem with hard drive!
Oct 18, 2009 | Gateway Essential 450cs Deluxe (ESSENTIAL...
Gateway 420 gr needs an upgrade hard drive
Yes you can upgrade the hard drive of this computer , you just need to get a Serial ATA hard drive from any electronic / computer store nea you like best buy or some store like amazon and others..
Jan 21, 2009 | Gateway (M520HD80G) Hard Drive
Gateway (M520HD80G) Hard Drive Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
