Question about RCA HD52W59 HDTV Projection Television
What causes the color to go out of linement? - RCA HD52W59 HDTV Projection Television
  • RCA Master
  • 8,617 Answers
If the convergence doesn't save its settings its usually related to the small signal board having the issue.
Posted on Nov 10, 2010
What can I apply to remove the pain that is remaining inside my skin
Try to apply linement oils it sooths the pain inside
Feb 14, 2017 | The Health & Beauty
What is the best linement of the blades for maxiunm lift for mower vacumm
There is no linement for the blades as the blades you buy now days has a great amount of lift just be sure you keep your blades sharp and watch your grass if the mowed grass has jagged edges then the blades are getting dull. But your blades won't stay in line anyway, as the grass will change them. Good luck, and let me know if you need anything else....
Aug 21, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Set timing 95 windstar 3.8
Hello, Ford Windstar timing for the timing of the crankshaft in reference to cam shafts. First, you'll need an auto repair manual for 1995 Ford Windstar with 3.0 engine. Any auto store will have these auto manual for those who like to do it their self's.
Read the disassemble instruction make careful notes on where parts when they come off and where they go back. Follow the linement instruction for the cams and the crankshaft. These lineament marks on the cam sprocket and the cam drive gear on the crankshaft will have to be in there proper location--timing marks. Double or even triple check this lineament procedures and what is specified in the repair manual. I hope this will really help you out. GB...stewbison
Oct 19, 2011 | 1995 Ford Windstar
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
Magenta color problem
This can be caused by one color not printing ...either from the lack of toner or the cartridge not being seen as full ..To reset them follow this procedure..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
This will override the toner level in the cartrdges and allow it to print all colors..and probably get rid of teh problem ..Usually the magenta predominant printing is caused by the lack of yellow color ..so watch it cause this one might empty first and cause it again if this procedure fix it for now ..There is a possibility that it is already out ..(empty )
Jan 28, 2011 | HP Color LaserJet 2600n Printer
My printer is Fuji xerox 1250, Recently i have a problem for the color issue, we tried color Calibration, We changed drum, we even reset to manufacturer default setting (by press 0+ green button and...
It seems your yellow color is not function correctly. Need to check yellow color feed and its linkage to deliver ink to your paper. Looks like it almost clog up that cause very light color in your paper. Again please check completely your color feeds.
Regards,
Dec 15, 2010 | Fuji Office Equipment & Supplies
The picture looks like a bowtie and red blue and
TURN YOUR COLOR OFF.IF YOU SEE THE RED,BLUE AND GREEN AROUND THE EDGES EX.SOMEONES FACE YOU CONVERGANTS IS OUT NEEDS RE LINEMENT.
Apr 24, 2010 | RCA Televison & Video
Samsung 61' DLP Color problem.
If you are using Component inputs, check to make sure that the Blue Video Cable has not backed out of its connecting jack at either end or the cable it's self being bad. If you are using HDMI I would suspect that the Digital Board being bad. It would be odd for the Color Wheel to cause the problem but cannot eliminate it as a cause. The Lamp would cause the picture to be darker but not cause a color to drop out.
I would call a professional to trouble shoot it unless you have the knowledge and the tools to do so.
Hope this helps,
Skyassoc
Jul 04, 2009 | Samsung HL-P6163W 61" TV
Nentendo Ds - Touch Screen - Linement
Hi did you try the calibration test in the ds settings. And if it is a new ds there might be something wrong with it. Or sometimes when you hold it at a weird angle it looks like you're touching one thing but you're touching something different.
Dec 29, 2007 | Nintendo DS Console
RCA HD52W59 HDTV Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
