When, I turn the tv on the picture is blury and fuzzy looking. After it is on for awhile it will clear up. When I turn it off agian it does the same thing. It just started doing it two days ago. Now when i wait for it to clear up it is taking longer and longer to clear.
  • 616 Answers
I have to say this not only for you, but for the benefit of others. Its usually important to those who need assistance as well as those who are willing to give it, to know what we are talking about. I don't know maybe like a model # or how old the equipment is, or if it has been serviced before. Its also a good idea to include the signal type you are using, DVD, VCR, cable, satellite, if other units in your home are doing the same or are ok. Just a comment, good luck
Posted on Nov 08, 2010
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a laptop inspiron 1525 vista. and everytime i turn it on it's always blury and fuzzy red on the screen all over!...why?! someone please help.
is the VGA driver installed?fine if it is....try connecting to an external monitor...if u still get the same blury or fuzzy red on the screen or all ova...have an expert look @ it and possibly change it.
Nov 11, 2009 | Computers & Internet
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Mitsubishi big screen blury
In all probability the picture is fuzzy too, its just harder to notice. This can be as simple as an adjustment in the back of the set. Carefully remove the back and look for the flyback transformer (part with large red wire coming out of the top). The should be 1 or 2 controls on it. One should be marked focus. Adjust that to get sharper focus.
Let me kow if that fails to resolve the problem.
Thanks,
Dan
Sep 30, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
