Question about Sonic Impact Technologies IF22 Docking Station for Apple iPod (648027050846)
Do you know where i can buy the ipod adapter pieces for the sonic impact speakers model IF2? a tel# would be helpful. thanx a bunch:)
  • 11,896 Answers
First place i'd try would be amazon.com
Posted on Nov 08, 2010
The sound has stopped working on my sonic impact I fusion and I have no idea why please help
the part were my ipod plug into Sonic Impact i-Fusion is very loose and at times will not play music- I need to put presser on the ipod to play music - how can I fix this loose ipod plug in?
Aug 24, 2010 | Sonic Impact Technologies i-P23 Portable...
I have a Sonic Impact V55 Video player and a new 160GB Ipod. Anyway to get the video to work on it?
Absolutely, I have this myself. My 5th Gen works great, but the 160GB would not show movies, just played music. Apple has an adapter cable set that allows you to hook your Ipod to your TV. $50 buy it! You can charge and watch your stuff on your flat screen. It also unlocks your Ipod TV out setting for your Video 55. Set you IPOD video setting to TV Out: on, select your movie and play. Plug in the IPOD nip to your Ipod then set your Ipod into the Video 55. A bit of a pain but works flawlessly. If you select a different movie you have to do this all over again.
Oct 30, 2009 | Sonic Impact Technologies Sonic Impact...
Can any ac adapter be used with sonic impact IF2? Or does it have to be the charger made just for that device?
Just make sure that the VOLTAGE and MILIAMP input rating match what it says on the Sonic unit itself, and that the connector is the correct size. More importantly, make sure that the polarity of the plug is correct. Some are inner connector = positive and outer connector = negative or vice-versa. That also should be on a sticker on the Sonic unit or embossed into the case near the connector. DC voltage is UNFORGIVING when the polarity is reversed. The unit itself doesn't care WHAT is supplying the current to run it AS LONG AS ALL THE ABOVE FACTORS ARE MET. If this has been helpful, please rate it accordingly. Thanks and good luck. FYI: check eBay for universal power supplies that include different tips. One should fit your unit. $15-$30
Jul 15, 2009 | Sonic Impact Technologies IF22 Docking...
New unit doesn't charge IPOD when plugged into 110v
make sure you have the cord plugged in to the DC IN 9V outlet in the speakers and not the audio in. Sounds simple but this is what I was doing wrong.
Jun 09, 2009 | Sonic Impact Technologies i-P23 Portable...
Sonic Impact iF2 Not charging
Hey how do I find a replacement battery for the Sonic Impact I F2?
May 07, 2009 | Sonic Impact Technologies IF22 Docking...
How do I get a manual on a Sonic Impact Technologies iF2
I kept "attacking the internet" until I found their home page and down loaded the manual. Bill Geist
Mar 02, 2009 | Audio Players & Recorders
Contact info for sonic impact technologies???
I found a website that had the phone # of their head of Technical Support (http://www.waves.com/objects/pdf/press/press_sonic_impact01.pdf ) It appears his name is “Big” Rich Bracke and his # is (760)944-0274.
Feb 03, 2009 | Sonic Impact Technologies i-P23 Portable...
Sonic impact i-P23 quit working with AC adapter & with batteries
Same problem. Speakers blew out and you can't get a hold of ANYONE at the company. You might want to try contacting the co-founder and principal Richard Bracke at BigRich@si-technologies.com (not sure if it's his correct email but I'm going to try it) or writing a letter to him at: Address: 255 State St., San Diego, CA 92101-1315
Jan 19, 2009 | Sonic Impact Technologies i-P23 Portable...
Docking connector for sonic impact if2
Had the same problem for a while, not been able to find any useful info anywhere.
Got a little bored today and decided to have a go myself.
First remove the battery.
The exterior zipped cover is glued to the plastic electronics compartment, careful prising (the cover is fairly flexible) can loosen the glue enabling you to remove the compartment.
Unscrew the plastic cover under this you will see the the pcb that the dock connector is attached to, along with lots of glue holding the wires for the speakers.
Unscrew the pcb and remove all the pcb connectors (all glued secure), then you will have access to the side you need to solder.
Now all you need is a hawk-eyed soldering genius as the tabs on the connector are extremely fine and closely spaced.
After testing I'd also recommend gluing the dock connector to the pcb for added future security.
Hope this helps.
Mar 28, 2008 | Audio Players & Recorders
Sonic Impact Technologies IF22 Docking Station for Apple iPod (648027050846) Logo
118 people viewed this question
Top Sonic Impact Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
jscuin6
Tom Chichester
Are you a Sonic Impact Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
