Question about SkyScan 86709 Atomic Wall Clock
I HAVE A SKYSCAN ATOMIC CLOCK MOD.#86722 OUT TEMP. DOSE NOT WORK I GHANGE BATT. 4 DIFF WAYS AN NOTHING HAPPENS. CAN I BUY THIS ITEM AND WHAT DO YOU $$$$$ FRANK
  • 6,826 Answers
Clean the contacts and make sure the batteries are inserted with the right polarity.
+ to + and - to - contacts.
I had a barometric pressure and temperature lcd item that had bad or dirty contacts in the battery compartment and it would intermittently work after jostling the batteries around.
Maybe bend the tangs (if out of warranty) so that a tighter contact is made. Clean them with a pencil eraseer, as well, to get the unit to get power from the batteries.
Good luck on this repair.
Posted on Nov 08, 2010
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
How program all things in the clock?
Howdy. Skyscan cannot locate your model number, but think the guide for a slightly different model should work. Here is the link to the instruction manual at skyscan's website: http://skyscaninfo.com/content/manuals/25-model-86722.html
I hope this gets you going:)
Aug 20, 2010 | SkyScan 86742 Digital Atomic Wall Clock
How to set on central time zone.
Hello. The instructions to set these clocks are rather lengthy so here is the website. Find your model, or one like it and the directions are very straight forward. Regards, Joe
http://skyscan.info/content/manuals/25-model-86722.html
Dec 04, 2009 | SkyScan 86709 Atomic Wall Clock
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Clock adds 1 hour overnight
There's no downloadable manual, but the manufacturer has it on a page here. As for the time changing overnight, make sure you have the right time zone set. It's probably wrong now, and the clock is resetting itself each day to what it thinks is the right time.
Apr 01, 2009 | SkyScan 86709 Atomic Wall Clock
Changed batteries
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
SkyScan 86709 Atomic Wall Clock Logo
109 people viewed this question
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
