Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Instead of depositing nice rounds discs of coffe grounds into the groiunds container, my machine now spreads coffee grounds all over the inside of the machine with no compact discs in sight.
I had the same problem about a month ago and contacted customer services because its still in warranty - they suggested it may be the diffuser and sent a new one - which solved the problem. The attached invoice showed it as costing GBP 15.03 (although it was free under warranty).
Posted on Nov 09, 2010
    Problem Solver:
  • 7 Answers
Yep, ours was doing the same thing and we bought another infuser and it took care of the problem. You can buy the part online at www. ereplacementparts.com by just typing in your model and then clicking the blue button that says "View Diagram and Parts List." We just replaced the generator on ours. They're pretty reasonable.
Posted on Jan 23, 2013
  • 1 more comment
  • condurso
    condurso Apr 09, 2013
    Do you mean the entire infuser which is listed as diffuser kit on ereplacement? Or just the metal disk which is called the diffuser?
  • Yolanda Heitman Apr 09, 2013
    Yes the diffuser kit (#77) at ereplacementparts. You also need to get a flashlight, take the diffuser out and look up into the right hand corner of the compartment. You'll see a head there with a big red o-ring. If that o-ring is worn out or torn it could be failing to compress the coffee disks. The diffuser actually rises up and tilts to the right and mates up with that head where the coffee is compressed and the hot water is forced through this tight connection. The red gasket is located in the exploded diagram at ereplacementparts as #64. On part 64 you'll see a gasket #74 and that is the red gasket that seals the main process. The machine is very easy to take apart and replacing the o-rings is a good idea to do at least once a year. If you have questions, please feel free to call us as we've fixed our machine at least 3 times in the past five years. We screen calls so leave a message. 253.884.4339
  • condurso
    condurso Apr 10, 2013
    I have already taken the whole thing apart including the infuser so I know exactly what you are talking about. The o-ring looked fine as did everything in the infuser, but I will give this a try. Ereplacement is very good and will let you return parts if they don't end up fixing your problem. I'll buy the diffuser kit and a couple o-rings just in case. Thanks for your quick reply!
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Hi, can you adjust the portion size of beans ground per cup for a saeco rotel conforta automatic espresso machine. The coffew is coming out fine, but too weak.
In the waste basket you got a nice round coffee puck i think you need to ajust the grinder its not chopping fine enough press for a coffee and put the dial down 1 like if your at 6 put 5 remmember the coffe you grind will take 2 coffe to reach try a couple and if your satisfied good if not go down on more try again
Mar 29, 2015 | Saeco Coffee Makers & Espresso Machines
Why is my F9 dispensing coffee directly into the grounds container instead of out the spouts?
From your description I would say a broken O ring seal in the brewing chamber. You will need to remove the brewing unit and clean, replace seals and lubricate the sliding guides.
Dec 07, 2014 | Jura Capresso Impressa F9 Espresso Machine
The flow of coffee is really slow
try to large the granulates the cofee ground. inside the coffe tank is the numbering disc. try to put him exemple: is at 5 put it to 7 and make 3 coffe then the flow of coffe will go faster
Sep 29, 2014 | Saeco Spidem Villa Espresso Machine
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Problem machine
Try replacing the O ring in the brew unit part number: NM01.044
Oct 27, 2008 | Saeco Royal Digital Plus Coffee...
Problem with Saeco royal digital plus
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
522 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
